eddie wrote:
: 4.) I know everything happens a little faster, but, other than that do they : have any nasty little gotchas. (like the narrow CG range on some Bonanzas) I own a PA-28-180 and I borrow a Mooney 201 as much as I can. The first little bit of flight time was "oh my gawd look at the ground going by" fast. After a little bit, it wasn't really a big deal - although the plane I borrow *does* have speed brakes. People will complain about the small cabin, but I haven't found that a problem. The shoulder room is actually better than a Cherokee. Headroom is a little different: the top of the Mooney is almost circular in cross section against the Cherokee's almost square cross section, so your head is much closer to the cabin roof. I find the rudder pedals to be the most annoying, as it seems un-natural to bend my ankles to the angle needed to push rudder and no brake. The plane I fly has crank-up height adjustable seats, I am not sure if these are common or not but I would recommend them! There is one important service bulletin on tube-frame corrosion. The front of the fuselage is steel tubes, and they can rust if the paint is not in good shape. This can be expensive to fix! : I've looked at Mooney.com and mooneyowners.com but no really useful info : there. Just looking for experienced Mooney drivers to shed a little honest : light. Try mooneypilots.org as well. -- Aaron Coolidge (N9376J) |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Looking for info on Flyins | Chris Whitley | Home Built | 21 | February 11th 04 09:21 PM |
Mooney to Offer Light Sport Airplane | Rick Pellicciotti | Home Built | 4 | September 24th 03 01:08 PM |
Cirrus vs Mooney | Charles Talleyrand | Owning | 6 | July 8th 03 11:35 PM |
