Jay Honeck wrote:
Replace the standard GE 4509 with a Q4509 (Quarts Halogen). They're usually about $25, instead of $10. I haven't run anything but Q4509s since '98. They're better, and last longer -- but they still suck. I guess you could always install some of those landing lights that mount in the leading edges of the wings. It's a shame that 235's can't use the ones that mount in the wingtips. I'm sure someone must make a kit for the Cherokees. --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
The skytec lights can be used on a 235 or Six with the fiberglass tip tanks.
They get installed in the leading edge of the wing, inboard of the tip. I have them on my PA-32. They cost me a tad over $1K to install in 1997. Jay Masino wrote: Jay Honeck wrote: Replace the standard GE 4509 with a Q4509 (Quarts Halogen). They're usually about $25, instead of $10. I haven't run anything but Q4509s since '98. They're better, and last longer -- but they still suck. I guess you could always install some of those landing lights that mount in the leading edges of the wings. It's a shame that 235's can't use the ones that mount in the wingtips. I'm sure someone must make a kit for the Cherokees. --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
tanks. They get installed in the leading edge of the wing, inboard of the tip. I have them on my PA-32. They cost me a tad over $1K to install in 1997. Any trouble with leakage into the wing structure? I've got a friend with a Bellanca, which has a similar leading edge landing light. Water infiltration through the landing light structure is a potentially major problem area with the Bellanca's wooden wing. I would suspect the bulbs last considerably longer, so far from the source of vibration -- true? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I changed two landing light bulbs in the 9 years I had my Super Viking...
Never had water infiltration... I simply used a thin bead of non hardening marine caulk around the perimeter of the plexiglass... denny "Jay Honeck" wrote I would suspect the bulbs last considerably longer, so far from the source of vibration -- true? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I haven't had any problems with leaks around the lights. I get much more water
in around the gas tanks and in the lap joint in wing skins than I do around the lights. I've only replaced one bulb in the wings in 700+ hours since installing them. I have the skytec version of the pulse light on them, which is turned on for every flight. In the same amount of time, I've gone through a half dozen nose light lamps, and that one is only on during approach at night. Jay Honeck wrote: The skytec lights can be used on a 235 or Six with the fiberglass tip tanks. They get installed in the leading edge of the wing, inboard of the tip. I have them on my PA-32. They cost me a tad over $1K to install in 1997. Any trouble with leakage into the wing structure? I've got a friend with a Bellanca, which has a similar leading edge landing light. Water infiltration through the landing light structure is a potentially major problem area with the Bellanca's wooden wing. I would suspect the bulbs last considerably longer, so far from the source of vibration -- true? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
water in around the gas tanks and in the lap joint in wing skins than I do around the lights. I've only replaced one bulb in the wings in 700+ hours since installing them. I have the skytec version of the pulse light on them, which is turned on for every flight. In the same amount of time, I've gone through a half dozen nose light lamps, and that one is only on during approach at night. Wow -- now that is a ringing endorsement. Hell, at the cost of bulbs, you'll pay back a goodly portion of the installation costs in a matter of years. Thanks, Ray. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
Alternative to Aero-NUT-Network | RobertR237 | Home Built | 3 | April 21st 04 09:29 PM |
Alternative to Jeppesen binders? | Ditch | Instrument Flight Rules | 35 | April 12th 04 05:18 AM |
Alternative for Mitchell quartz clock w. ELT hands | Rob Turk | Home Built | 0 | March 1st 04 10:23 AM |
Bell X-1 sonic boom. | Ed Majden | Military Aviation | 4 | December 2nd 03 05:20 AM |
