Piper Pacer V-speeds
Old March 25th 04, 12:28 AM
MikeM
John Galban wrote:
This brings up an interesting question. Most folks I know that have
converted Tri-Pacers to taildraggers now call them Pacers. I believe
there are more PA22/20 conversions than there are actual PA20s. That
being the case, do you know if the PA22/20 conversion removes the
interconnect? If not, the I'll bet a lot of "Pacers" could be said to
have the interconnect.
The interconnect is removed per the STC that comes with a
conversion kit purchased from Univair. NonSTC conversions using
Piper's original PA20 drawings remove the interconnect because
the PA20 didn't have one; it was an "innovation" when Piper
came out with a PA22.
MikeM
Pacer '00Z
Old March 25th 04, 09:41 PM
John Galban
MikeM wrote in message ...
I had also emailed my question to an A&P friend that owned a PA22/20
and his answer (relating to the STC) was "it depends". Here's his
response :
"It depends on the original horse power. If you had a 135 hp the
spring stays in place. If you had an original 135 hp, converted it to
150 hp, the spring stays. If you had an original 150 or 160hp and
converted it, you remove the spring. That's just the way the STC was
written.
Also if you go to 180 hp add a constant speed the spring stays or is
added."
Piper Pacer for sale GASSITT Aviation Marketplace 0 February 5th 04 03:34 PM
Piper Pacer for sale GASSITT Home Built 0 February 5th 04 03:31 PM
Piper Pacer for Sale GASSITT Aviation Marketplace 0 January 25th 04 02:36 PM
Piper Pacer for sale GASSITT Aviation Marketplace 0 January 9th 04 01:53 PM
Piper Pacer for sale GASSITT Aviation Marketplace 4 December 27th 03 12:42 AM
