Kitplanes Columns
Old April 8th 04, 04:40 PM
Jim Weir
George Patterson took the task on and has done an absolutely splendid job
translating the first article.
To have a looksee a George's handiwork, www.rstengineering.com/kitplanes and go
to the bottom article (July '02).
George, the gang owes you one, and so do I.
The August '02 raw data is posted in the usual place.
-Again I ask...is anybody fool enough to take my Kitplanes column raw data and
-put it into downloadable format for the rest of the gang?
http://www.rst-engr.com
Old April 8th 04, 06:32 PM
Dave Butler
Not Found
The requested URL /kitplanes/KP0207/KPtext.pdf was not found on this server.
Apache/1.3.20 Server at www.rst-engr.com Port 80
Dave
Old April 8th 04, 06:42 PM
frank
Works in Texas...
"Dave Butler" wrote in message
and go
Not Found
server.
Dave
Old April 8th 04, 06:59 PM
Russell Kent
Not Found
Dave
There's two mismatches between the KP0207.htm file and the other files: the parts
list file and full test PDF are Kpparts.pdf and Kptext.pdf on the webserver, but are
KPparts.pdf and KPText.pdf in the URLs in the KP0207.htm file (note the case
difference in the "P"s). So the real URLs to the full text and parts list a
http://www.rst-engr.com/kitplanes/KP0207/Kpparts.pdf
http://www.rst-engr.com/kitplanes/KP0207/Kptext.pdf
I imagine that the above to references will break here shortly when Jim fixes the
KP0207.htm file or renames the PDFs.
Russell Kent
Old April 8th 04, 06:34 PM
Jim Weir
George...
In terms that any competent history major can understand, can you tell me how
you want me to fix this type mismatch?
-There's two mismatches between the KP0207.htm file and the other files: the
parts
-list file and full test PDF are Kpparts.pdf and Kptext.pdf on the webserver,
but are
-KPparts.pdf and KPText.pdf in the URLs in the KP0207.htm file (note the case
-difference in the "P"s). So the real URLs to the full text and parts list
a
-http://www.rst-engr.com/kitplanes/KP0207/Kpparts.pdf
-http://www.rst-engr.com/kitplanes/KP0207/Kptext.pdf
-I imagine that the above to references will break here shortly when Jim fixes
-KP0207.htm file or renames the PDFs.
-Russell Kent
Old April 8th 04, 09:33 PM
G.R. Patterson III
Well, the fastest way to fix it is to rename the two files to match the URLs.
Alternately, I can change the URLs in the html file and resend that. If you go the
first route, rename "Kpparts.pdf" to "KPparts.pdf" and rename "Kptext.pdf" to
"KPText.pdf". The difference in names also exists on my computer; the reason I didn't
catch it is that the link still works for me. It didn't show up in testing.
I'll double-check for that sort of thing with August.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 8th 04, 10:49 PM
FUji
"G.R. Patterson III" wrote in message
me how
URLs.
you go the
to
reason I didn't
testing.
George Patterson
to
home
Easiest in the future to use all lowercase for filenames and URLs. It
avoids problems with Win/DOS being case insensitive.
Old April 10th 04, 03:23 AM
G.R. Patterson III
I am now FTPing the files up to a directory on my web site for testing. Since most
web servers are UNIX boxes, I expect that any problems in this regard will pop up
immediately.
George Patterson
Old April 9th 04, 02:32 AM
UltraJohn
Some web authouring software (Windoze based) will use upper/lower case in
the program and html files then safe the respective files in all lowercase
which works ok if your ISP uses a Windows based web server, but with a lot
of servers running Linux OS and Apache web server it will not work if you
use FTP to upload your files but probably will work if you use their
program to "publish to the web".
I have 3 web sites I maintain and I have to manually edit the HTML files
each time I update to correct the case problem.
John
G.R. Patterson III wrote:
how you want me to fix this type mismatch?
URLs. Alternately, I can change the URLs in the html file and resend that.
If you go the first route, rename "Kpparts.pdf" to "KPparts.pdf" and
rename "Kptext.pdf" to "KPText.pdf". The difference in names also exists
on my computer; the reason I didn't catch it is that the link still works
George Patterson
to play "Your cheatin' heart", and the bride just requested "Don't
come home a'drinkin' with lovin' on your mind".
Old April 9th 04, 05:33 AM
David Lesher
"G.R. Patterson III" writes:
Please... keep all file names lower case. Also, please, please be really
pedantic on URL filesnames:
Only:
0-9, a-z, _ - .
No other characters. No !@#$:;%^&*()+|\/ {I swear I must have seen
each one in some URL sometime.}
Yea, you may get away with it for a while, until you start getting
into cross-platform situations. Then you have a mess.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Does anyone have Kitplanes Mag's from 1986? Nunya Home Built 10 June 21st 11 07:22 AM
unfair cartoon in October 2004 issue of KITPLANES Bob Kaplow Home Built 31 August 29th 04 02:00 PM
Columns by a Canadian centre controller David Megginson Instrument Flight Rules 1 August 9th 04 10:05 PM
Kitplanes August Issue Badwater Bill Home Built 28 July 6th 04 08:26 PM
Kitplanes Columns Jim Weir Home Built 30 April 14th 04 08:23 PM
