Ron Rosenfeld wrote in message . ..
It came with an electric bifold door. In spite of winter ice and snow, the door has never given any trouble whatsoever. No tracks in the ground to freeze up or buckle. The only time I couldn't open the door was when the airport had a power failure. I would do it again. Biggest problem with a bifold is tail height. For my aircraft, it makes the door framing a heck of a lot bigger than I really want. For a tail height of 15' on one of mine, it makes the bifold opening a minimum of 20' tall. When you couple that with a required span of 60', it makes for a very expensive door that has to be power operated, along with some significant structural needs. For my purposes, a biflod would end up costing nearly as much as the rest of the hangar itself. Craig C. |
Not these doors, which is what I have. They have the aux arms on the sides which allow them to open further with a given
opening... http://www.hi-fold.com/ -- Dan D. .. "Craig" wrote in message om... Ron Rosenfeld wrote in message . .. It came with an electric bifold door. In spite of winter ice and snow, the door has never given any trouble whatsoever. No tracks in the ground to freeze up or buckle. The only time I couldn't open the door was when the airport had a power failure. I would do it again. Biggest problem with a bifold is tail height. For my aircraft, it makes the door framing a heck of a lot bigger than I really want. For a tail height of 15' on one of mine, it makes the bifold opening a minimum of 20' tall. When you couple that with a required span of 60', it makes for a very expensive door that has to be power operated, along with some significant structural needs. For my purposes, a biflod would end up costing nearly as much as the rest of the hangar itself. Craig C. |
On Sat, 17 Apr 2004 01:52:50 GMT, "Blueskies" wrote:
http://www.hi-fold.com/ Dig the photo of the hangar-house on the right, on the "Applications" page! all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
Thanks for the link. Very helpfull
Jean-Paul "Blueskies" wrote in message m... Not these doors, which is what I have. They have the aux arms on the sides which allow them to open further with a given opening... http://www.hi-fold.com/ -- Dan D. . "Craig" wrote in message om... Ron Rosenfeld wrote in message . .. It came with an electric bifold door. In spite of winter ice and snow, the door has never given any trouble whatsoever. No tracks in the ground to freeze up or buckle. The only time I couldn't open the door was when the airport had a power failure. I would do it again. Biggest problem with a bifold is tail height. For my aircraft, it makes the door framing a heck of a lot bigger than I really want. For a tail height of 15' on one of mine, it makes the bifold opening a minimum of 20' tall. When you couple that with a required span of 60', it makes for a very expensive door that has to be power operated, along with some significant structural needs. For my purposes, a biflod would end up costing nearly as much as the rest of the hangar itself. Craig C. |
"Blueskies" wrote in message om...
Not these doors, which is what I have. They have the aux arms on the sides which allow them to open further with a given opening... http://www.hi-fold.com/ They don't gain as much headroom as you think. By their own spec's, the vertical height of the door opening will need to be nearly 30" over the height that I would need. Besides, here in the summer time heat and wind, a bifold is a PITA. It's too hard to regulate airflow through the hangar. Craig C. |
On Sat, 17 Apr 2004 10:42:56 GMT, "Blueskies" wrote:
My hi-fold was $3500 for 45 wide by 12' clear opening. That is just the cost of the frame, which then has the r-board and metal exterior attached, not to mention the installation costs (hanging it, electrical hookup, etc.) It you have no power a roller/track door is the way to go... -- Dan D. That is likely less than I paid for mine, but the price of my kit did not have the door price listed separately. The kit included not only the door, but also all of the other metal parts required to build the entire hangar. I don't know all the names but that would include the hangar supports, door framing, motor for the door, bolts, exterior metal sheathing. On site we supplied some lumber which ran between the steel supports and to which we nailed the exterior sheathing. The rest of the erection costs had to do with labor, excavation, concrete floor, and asphalt. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Ron Rosenfeld wrote:
On 16 Apr 2004 13:23:30 -0700, (Craig) wrote: Ron Rosenfeld wrote in message . .. It came with an electric bifold door. In spite of winter ice and snow, the door has never given any trouble whatsoever. No tracks in the ground to freeze up or buckle. The only time I couldn't open the door was when the airport had a power failure. I would do it again. Biggest problem with a bifold is tail height. For my aircraft, it makes the door framing a heck of a lot bigger than I really want. For a tail height of 15' on one of mine, it makes the bifold opening a minimum of 20' tall. When you couple that with a required span of 60', it makes for a very expensive door that has to be power operated, along with some significant structural needs. For my purposes, a biflod would end up costing nearly as much as the rest of the hangar itself. Craig C. I really have no idea regarding door costs. The kit with a 40x10 bifold door was about $13K (engineered for northern climes). That was less than half the total construction cost. I have no idea what a larger hangar would cost. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) my folding doors cost me about 500 more than just building the original wall, anf they open in less than a minute, even with the electric power off, 13K for door, not doors ? you guys have more money than brains ! -- Mark Smith Tri-State Kite Sales http://www.trikite.com 1121 N Locust St Mt Vernon, IN 47620 |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Instrument Flight Rules | 10 | April 19th 04 12:37 AM |
wanted: hangar door tips | Joa | Home Built | 35 | April 18th 04 02:19 PM |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Naval Aviation | 0 | April 6th 04 12:58 AM |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Military Aviation | 0 | April 6th 04 12:58 AM |
The Auction Hangar - Completely free aviation auction site. | The Auction Hangar | Instrument Flight Rules | 0 | April 6th 04 12:57 AM |
