Hi,
Here is a new design challenge for those of you with homebuilts with all the bells and whistles. The 2004 Toyota Prius hybrid car has a Denso electrically powered air conditioning compressor that apparently does not need to be mounted on the engine. This offers the possibility of reasonably putting A/C in a homebuilt airplane. What comes to mind is one of these systems mounted in the aft fuselage (one way to overcome a nose heavy design) with a duct (with a retractable scoop) for air for the condensor. For some details go to: http://www.denso.co.jp/motorshow/200...duct_electric/ Fly safe, have fun, be cool, Jim Payne |
"JPAviation" wrote in message ... The 2004 Toyota Prius hybrid car has a Denso electrically powered air conditioning compressor that apparently does not need to be mounted on the engine. Jim Payne It's all about weight. How much? Plus how much bigger ya gotta make the alternator. What's wrong with an engine mounted AC? -- Jim in NC |
JPAviation a écrit:
The 2004 Toyota Prius hybrid car has a Denso electrically powered air conditioning compressor that apparently does not need to be mounted on the engine. This offers the possibility of reasonably putting A/C in a homebuilt airplane. What comes to mind is one of these systems mounted in the aft fuselage (one way to overcome a nose heavy design) with a duct (with a retractable scoop) for air for the condensor. I know only one way to have a cool flight during summer: I climb, and when I read 18°C (65°F) OAT, I level off. By -- Philippe Vessaire Ò¿Ó¬ |
Philippe Vessaire wrote:
The 2004 Toyota Prius hybrid car has a Denso electrically powered air conditioning compressor that apparently does not need to be mounted on the engine. This offers the possibility of reasonably putting A/C in a homebuilt airplane. What comes to mind is one of these systems mounted in the aft fuselage (one way to overcome a nose heavy design) with a duct (with a retractable scoop) for air for the condensor. I know only one way to have a cool flight during summer: I climb, and when I read 18°C (65°F) OAT, I level off. By No good for a 45min taxi on the ground in Florida summer. But what's wrong with an icebox. Lightweight aluminum box, with passages through the bottom. Pass vent air through it and into the cockpit. Fill the box with ice and it should last until you reach the 65* air. Very little extra weight in the winter, or when you're in the cruise configuration (it'll have melted by then. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Ernest Christley a écrit:
Philippe Vessaire wrote: I know only one way to have a cool flight during summer: I climb, and when I read 18°C (65°F) OAT, I level off. No good for a 45min taxi on the ground in Florida summer. But Sorry, I never have 45mn taxi here, on light aviation airfieds... 5mn is a maxi.... 45mn or more is on commercials airports, in "my" A320. By -- Philippe Vessaire Ò¿Ó¬ |
JPAviation wrote:
: The 2004 Toyota Prius hybrid car has a Denso electrically powered air : conditioning compressor that apparently does not need to be mounted on the : engine. This offers the possibility of reasonably putting A/C in a homebuilt : airplane. What comes to mind is one of these systems mounted in the aft : fuselage (one way to overcome a nose heavy design) with a duct (with a : retractable scoop) for air for the condensor. Probably not feasible. Even a small AC unit will require many hundreds of watts.... usually 1kW or more. If you do the math, at 14v, that's almost 100 amps for just the AC. The hybrid can do it because it's got access to high-power (higher voltage too) electricity. Think of how many electric AC's are in conventional cars.... and how you have to turn off the AC in a four-banger going uphill. It takes a (relative) lot of power to run an AC compressor. -Cory -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
It's even easier to fly a Corben Junior Ace...full time AC!
-- Scott http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die "JPAviation" wrote in message ... Hi, Here is a new design challenge for those of you with homebuilts with all the bells and whistles. The 2004 Toyota Prius hybrid car has a Denso electrically powered air conditioning compressor that apparently does not need to be mounted on the engine. This offers the possibility of reasonably putting A/C in a homebuilt airplane. What comes to mind is one of these systems mounted in the aft fuselage (one way to overcome a nose heavy design) with a duct (with a retractable scoop) for air for the condensor. For some details go to: http://www.denso.co.jp/motorshow/200...duct_electric/ Fly safe, have fun, be cool, Jim Payne |
Scott wrote:
It's even easier to fly a Corben Junior Ace...full time AC! -- Scott Hi Scott! I know what you mean. A few years back we had an ice age here in Texas when it actually got cold in the winter. Burrr! Nearly snowed in San Antonio! Guys would make one (quick!) pass around the pattern and crowd around the fire and just LIE about it! "Naw, not that ccccold up there". "You get used to it!" "Thick air today. Lotta lift in it." And so the next brave soul screws up his courage and blasts around the pattern (real quick) once. Ah, the joys of an open cockpit. Richard Lamb |
On Tue, 03 Feb 2004 06:23:30 GMT, Richard Lamb
wrote: A few years back we had an ice age here in Texas when it actually got cold in the winter. Burrr! Nearly snowed in San Antonio! Guys would make one (quick!) pass around the pattern and crowd around the fire and just LIE about it! "Naw, not that ccccold up there". "You get used to it!" "Thick air today. Lotta lift in it." And so the next brave soul screws up his courage and blasts around the pattern (real quick) once. Ah, the joys of an open cockpit. Hmmmff. Sam Houston is probably turning over in his grave. I only flew twice in the last month, but both times it was below freezing...and I stayed up for almost an hour, each time. The last time, I had to abort landing at one airport because the snowplows hadn't got done clearing it...and when I buzzed ^H^H^H^H flew a low approach at another, I got to wave at the kids sledding down the hill at the end of the runway. I had some fun the first time, too. It was an absolutely clear, beautiful day, with the ground temperature at freezing and a 10 knot wind blowing right down the runway. I was wearing a turtleneck under my Fly Baby denim shirt, but my leather jacket didn't provide enough warmth even during preflight. So I added a sweatshirt. For the first time in several years, I pulled my spandex ski-mask out of the flight bag, and added the brand-new fleece-lined leather gloves Santa had brought. The temperfoam pad of Moonraker's seat was ice-hard when I slid down into the cockpit. The bulky clothes made it a bit tougher to gather the safety harness straps and plug the headset into the comm system. I was sweating a bit by the time I'd finally got myself attached to the airplane. The temperfoam had thawed a bit by then; I made a mental note to re-tighten the straps before takeoff. The Continental spun to life, and the propwash hurriedly made me drag up the ski mask to cover my nose and lower the goggles. After that, though...the flight was heaven. The airplane performed like a wonder in the crisp air, aided by a stiff 10 knot wind right down the runway. It shot off the ground like it was flung by a rubber-band catapult. As we rose, the snow-capped peaks of the Cascade range lifted above the horizon. A few bumps due to the wind, otherwise smooth. I did my usual cold-weather flying routine: Fly to the nearby airports, and do either a landing or a low pass so people could point and say to each other, "Look at that idiot in the open-cockpit airplane!" But I was comfortable...the combination of the leather helmet, ski mask, silk scarf, and turtleneck nicely kept the drafts away from any skin, and the cozy cockpit and heater handled the rest. Back to the home drome after forty-five minutes. I figured if I landed immediately, my friends would nod knowingly and say, "Guess Ron got too cold," so I shot some touch-and-goes first. As usual, the cold and the ski mask made it tough to enunciate on the radio, but people seemed to be able to decode calls like "Eye Baby Ayht four Ayht down ind f'r touch-and-o on Eeee four." After about a half-dozen bump-and-runs, I decided to call it a day. 'Raker was a bit low on gas, and I prefer to tank up on Avgas in the winter. So I taxied up to the gas pumps. Next to the pumps, I saw the new airport manager (whom I know fairly well), one of the airport staff, and a buddy huddled around an open equipment box installed on the wind-swept ramp. The Superunicom was down, and they were trying to get it working again. It's a fact of life that if you live in the Seattle area and don't own an open-cockpit airplane, you do NOT own much in the way of cold-weather gear. Seattlites may own five brands of raincoats, but other than maybe a ski jacket stuffed in the back of a closet, they're usually not equipped to spend much time outdoors in the cold. These three guys certainly weren't. With the stiff north wind, the wind-chill factor was probably in the teens. The manager just had a topcoat over his suit and the staffer a thin jacket. My buddy had a leather jacket on, but none of them had gloves or anything on their heads (old Swiss saying: If your feet are cold, put on your hat). Me, on the other hand...I was still fairly comfortable. But I'm sure after their time on the ramp, they probably *really* expected me to be half-frozen. I shut down Moonraker, took off my headset, climbed out, and strolled over to them, still wearing my helmet, ski mask, etc. "You know," I said, eyeing the shivering forms before me, "I would have picked a warmer day to work on that....." :-) Ron Wanttaja |
| Thread Tools | |
| Display Modes | |
| Paint system | Sam Fly | Home Built | 9 | December 2nd 03 01:47 AM |
| ALTRAK pitch system flight report | optics student | Home Built | 2 | September 22nd 03 12:49 AM |
| FA: halon fire ext system for homebuilts | N329DF | Home Built | 0 | August 16th 03 04:12 PM |
| 2nd update on Review of Plasma II Ignition System | MikeremlaP | Home Built | 8 | July 22nd 03 02:37 AM |
