Nubie Question: New or Used for New Pilot?
Old April 18th 04, 03:17 PM
C J Campbell
Among new airplanes you would have a choice of the Cessna 172S or a Diamond.
These planes will fit your mission profile quite well. The Diamond has a
wider cockpit than the Cessna.
Airplanes depreciate quite a lot the first three to five years then
gradually start to increase in value. Exceptions would be airplanes like the
Cirrus SR22 which has a severely restricted airframe life; some of these
planes are already approaching mandatory retirement.
Probably the best deals out there are used late model Cessna 182s.
Trade-a-Plane shows several of these as low as $170,000. The 1998 and 1999
model years were very good airplanes. There are also some used Cirrus SR20s
that are less than $200K and they still have a lot of life in them.
You could take an old airplane and re-paint it, put new interior and
avionics in it, a new engine, and guess what? It is still an old airplane!
It will never have all the safety features and capability of the newer ones.
The new Cessnas may have the same model designations as the older ones, for
example, but they might as well be different types. They are faster, more
fuel efficient, and far more comfortable. Everything from fuel systems to
avionics to engines has changed. Even the supposedly draggy airframe got a
thorough going-over.
Still, for the down payment that you put on one of these shiny suckers you
could buy an ancient 172 that will still fit your mission profile and you
won't have any monthly payments at all. You might even be able to afford to
fly the thing now and then. You could lose your job, but you won't have to
give up your airplane in order to be able to eat. Personally, I find far
more comfort and safety in staying out of debt than in having the latest new
thing. I would not buy an airplane that I could not pay cash for.
Old April 19th 04, 10:06 PM
ET
"C J Campbell" wrote in
snippage
more snippage
So you've flown over the 4000+hr current restriction and the 12,000 hr
restriction that will be in place by the end of the year???
ET
"A common mistake people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete
fools."---- Douglas Adams
Old April 19th 04, 11:37 PM
C J Campbell
"ET" wrote in message
snippage
more snippage
I have not. Good heavens. No, a couple of flight schools have said they are
getting close. They must fly the things constantly.
Cirrus has been promising that 12,000 hour restriction for years, now. I
wish them well. Then they can start figuring out why these things are
falling out of the sky. There just seems to be no good reason for it. I
suspect training is the issue.
Old April 20th 04, 07:38 AM
ET
snippage
these planes are already approaching mandatory retirement.
more snippage
hr restriction that will be in place by the end of the year???
they are getting close. They must fly the things constantly.
I wish them well. Then they can start figuring out why these things
are falling out of the sky. There just seems to be no good reason for
it. I suspect training is the issue.
After being in one myself (Not an experienced pilot talking here...) I
CAN see how the complex systems can be confusing until one gets used to
them. Then as you think,, hrm what screen is that on... what button
makes that happen.... how do I turn on the autopilot and program it
properly... your in imc and don't know which way is up and think the
guages are lying to you....
Interesting... one of the older cirrus accident reports mentioned that
the "please remove before flight" pin that keeps the CAPS handle secured
on the ground had never been removed. I wonder if that pilot was more
paranoid about the chute being pulled accidentaly than needing it in a
hurry.
Your right about the 5K hour issue. I saw some pretty ****ed off posts
on the cirrus owners assn forum talking about how cirrus didn';t exactly
bring that to there attention before they plunked down there 300+ large.
ET
Old April 20th 04, 05:38 PM
TTA Cherokee Driver
snippage
more snippage
wish them well.
I searched the online POH for the SR20 and could not find this
limitiation documented. Can you provide a link to documentation of this
limit?
according to the current issue of FLYING, they have stopped falling out
of the sky. Maybe the training has improved.
Old April 20th 04, 06:02 PM
C J Campbell
"TTA Cherokee Driver" wrote in message
these
more snippage
are
wish them well.
limit?
Ah, if it is not on the Internet, it must not be true, eh? :-)
The airframe life limit for the SR20 is 12,000 hours. The airframe life
limit for the SR22 is 4030 hours. The only place you will find that is by
reading the type certification. There may be some place you can find that on
the Internet. It is not in the POH for either aircraft, nor does Cirrus
mention it in any of their advertising or in the purchase agreement.
Well, there were two of them quite recently, but maybe "Flying" went to
press before those incidents occurred.
Old April 20th 04, 07:24 PM
TTA Cherokee Driver
wish them well.
limit?
Not at all, I just wanted a quick-n-easy link to point someone to.
the Internet.
That info sure makes the googling easier.
Found a reference to it he
http://www.airplanenoise.com/article....%20Cirrus.pdf
Getting the correct number (4350) off that website makes Cirrus's own
website be result #2 when googling on: sr22 4350 hours
http://www.cirrusdesign.com/aircraft/faq/index.html
It's definitely easy to find when you know the right info to google for.
The comparision site also says that TBO on the SR22 engine is only 1700
hours, that surprised me.
True. But those were not fatal accidents. An alarmingly high rate of
fatal accidents was the knock on Cirrus, as I recall. The latest FLYING
has a column by one of their regulars claiming the cirrus accident rate
is now roughly equivalent to that for 182's.
Old April 23rd 04, 07:57 PM
John Kazickas
anyone know how Diamond Aircraft compares to the Cirrus? Same airframe
life? how about safty record??
TTA Cherokee Driver wrote:
now. I
wish them well.
limit?
that on
the Internet.
Old April 21st 04, 02:49 AM
G.R. Patterson III
of the sky.
That would have been the opinion of the staff at Flying about three months ago.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
Enlisted pilots John Randolph Naval Aviation 41 July 21st 03 02:11 PM
