SR20 vs SR22 exhaust
Old April 27th 04, 10:22 PM
Jay Honeck
I'm not talking about sound, I'm talking about the pipes. They stuck
about 2' out of the bottom of the cowling on the SR20 I saw. Like giant
fangs... I see now that those are only on the SR20 -- the SR22 has much
shorter pipes.
Yep, they're ugly -- but I assume they are "tuned" exhausts...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old April 28th 04, 02:03 AM
G.R. Patterson III
Well, it may not equate, but the tuning on automotive systems is done in the header.
The length and bends of the pipes from the heads to the collectors is important, but
the length of the exhaust pipes is not.
George Patterson
If you don't tell lies, you never have to remember what you said.
Old April 28th 04, 02:49 PM
Jay Honeck
the header.
important, but
Hmmm. I thought that new "performance exhaust" system for Cherokees and
Skyhawks had to be "x" number of inches (feet?) long in order to "tune" the
exhaust, in order to increase horsepower "x" percent?
Isn't that why those things are so big, honkin' ugly, hanging out the bottom
of the plane?
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old April 28th 04, 03:05 PM
Dave Butler
the header.
important, but
of the plane?
Could be a marketing thing. People don't like to spend money on things that
can't be seen.
Dave
Remove SHIRT to reply directly.
Old April 28th 04, 07:17 PM
Greg Copeland
the header.
important, but
of the plane?
Well, I can't speak specifically to planes in this regard, but for
some other engines, that's the difference between turned exhaust and a
tuned pipe. The idea is that the pipe is used to improve scavenging
capabilities of the engine. Tuned pipes can often be used in
conjunction with performance headers (tuned exhaust) to improve
overall performance of the engine. The length and size of the pipe
directly relates to the targeted RPM range at which the improved behavior
is desired.
Headers are normally used to improve the ability of the engine to get
exhaust out of the engine. Likewise, pipes are normally used to effect
the scavenging abilities (helping to suck exhaust out of the engine). As
you can see, the two can be considered complimentary.
Granted, I don't normally associate pipes with 4-cycle engines. That
ignored, the length of the pipe, especially with performance headers can
also effect the backpressure on the engine. Too little backpressure can
lead to poor performance, just like too much can. AFAIK, it's not
uncommon to add a longer exhaust pipe to slightly increase backpressure to
compliment a performance header.
Old April 29th 04, 02:23 AM
G.R. Patterson III
Tuned headers work by the fact that, if you take tubes that are between 32" and 36"
long and hook one end of each to the exhaust port of the engine and the other end to
a collector tube, the flow of the exhaust from the first cylinder to fire will help
pull the exhaust out of the second cylinder to fire. I was told that the length of
the exhaust system after the collector doesn't matter. You can reduce the length of
the tubes in the header by adding bends; conversely, if you have to bend the tubes
for clearance reasons, you have to reduce the length. This is why most automotive
tuned headers look like pretzels.
George Patterson
Citabria 7ECA Exhaust Wanted Capt. Dave Home Built 2 February 2nd 05 04:20 AM
Cirrus Deploys Chute Safely m alexander Home Built 40 September 28th 04 12:09 AM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
YF-23 exhaust? Sir Loin of Beef Military Aviation 0 August 1st 03 04:55 AM
Exhaust Tape RobertR237 Home Built 19 July 30th 03 03:06 AM
