On Wed, 28 Apr 2004 13:49:41 +0000, Jay Honeck wrote:
Yep, they're ugly -- but I assume they are "tuned" exhausts... Well, it may not equate, but the tuning on automotive systems is done in the header. The length and bends of the pipes from the heads to the collectors is important, but the length of the exhaust pipes is not. Hmmm. I thought that new "performance exhaust" system for Cherokees and Skyhawks had to be "x" number of inches (feet?) long in order to "tune" the exhaust, in order to increase horsepower "x" percent? Isn't that why those things are so big, honkin' ugly, hanging out the bottom of the plane? Well, I can't speak specifically to planes in this regard, but for some other engines, that's the difference between turned exhaust and a tuned pipe. The idea is that the pipe is used to improve scavenging capabilities of the engine. Tuned pipes can often be used in conjunction with performance headers (tuned exhaust) to improve overall performance of the engine. The length and size of the pipe directly relates to the targeted RPM range at which the improved behavior is desired. Headers are normally used to improve the ability of the engine to get exhaust out of the engine. Likewise, pipes are normally used to effect the scavenging abilities (helping to suck exhaust out of the engine). As you can see, the two can be considered complimentary. Granted, I don't normally associate pipes with 4-cycle engines. That ignored, the length of the pipe, especially with performance headers can also effect the backpressure on the engine. Too little backpressure can lead to poor performance, just like too much can. AFAIK, it's not uncommon to add a longer exhaust pipe to slightly increase backpressure to compliment a performance header. |
Citabria 7ECA Exhaust Wanted | Capt. Dave | Home Built | 2 | February 2nd 05 04:20 AM |
Cirrus Deploys Chute Safely | m alexander | Home Built | 40 | September 28th 04 12:09 AM |
P-38 Exhaust | Stephen Harding | Military Aviation | 10 | April 19th 04 07:03 AM |
YF-23 exhaust? | Sir Loin of Beef | Military Aviation | 0 | August 1st 03 04:55 AM |
Exhaust Tape | RobertR237 | Home Built | 19 | July 30th 03 03:06 AM |
