At low RPM the cut out relay in the regulator is SUPPOSED to open so
that the battery does not BACKFEED into the generator. This is relay is apparently not opening. This relay has two windings, one of many turns of fine wire and the other is a few turns of heavy wire. When the generator is charging the two windings add to keep the relay closed. When the generator RPM is low the battery back feeds the generator and tries to run it as a motor. When this happens the fields of the two windings oppose each other and the armature contact to the battery opens. Since the circuit breaker has opened so many times it most likely will not hold rated current either. REPLACE THE VOLTAGE REGULATOR AND THE CIRCUIT BREAKER. JF On 03 May 2004 23:04:47 GMT, (JFLEISC) wrote: but your generator is capable of delivering only 30A, then the genny should be up to delivering its full rated 30A output all day long. It shouldn't care what the total bus load is... (turning on extra load should not trip the genny breaker) No argument here. But lets say that the FULL rating is 30A. What is the output if it is spinning at %10 of that full rated speed? How much current will now be going over those oxidized breaker contacts that seemed to handle the full speed output current OK? Jim |
Landing light | Hankal | Aviation Marketplace | 0 | July 14th 04 01:23 AM |
Would a 3 million Candlepower spotlight make a good landing light? | Legrande Harris | Home Built | 6 | June 15th 04 06:32 AM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
74 Archer Nav light switch | Mike Noel | Owning | 8 | January 14th 04 03:56 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
