![]() What type approach was in use? 800 and 2 miles is pretty good for an ILS. If he missed twice, what were the actual conditions at the DH? |
We had very changeable conditions here at that time. I was 10 miles north
of the accident site. 800 and 2 seems like about the worse we had during that period. No fog from what I could see. Some rain and it looked a bit turbulent/convective. But that is real speculation. "EDR" wrote in message ... What type approach was in use? 800 and 2 miles is pretty good for an ILS. If he missed twice, what were the actual conditions at the DH? |
EDR wrote
What type approach was in use? 800 and 2 miles is pretty good for an ILS. If he missed twice, what were the actual conditions at the DH? Well, the problem is you don't know. Yesterday I took a short businees trip in my plane. Conditions were forecast/reported as marginal VFR, so I filed. I got to the airport, and while it was slightly hazy, there was not a cloud in the sky and stuff 5+ miles away was clearly visible. Rather than messing with a void time, I took off VFR. My destination was GTU, only 115 nm away. (For those playing along on the home game, the approach there is available at: http://www.naco.faa.gov/d-tpp/0404/05724N18.PDF). So I'm cruising along at 2000 ft to stay out of the winds, enjoying the day, and I decide to give Flgh****ch a call to see if maybe the conditions over there have not improved. Well, they're still MVFR - 1000 SCT, 1600 NKN, 2200 OVC, vis 10+. OK, it's MVFR, and I can see the cloud deck in the distance so I climb and activate, but I'm expecting a total no brainer approach, or maybe even a visual. So I'm over the top, and I get switched to Austin. Austing asks if I have the weather, and I do - the latest is 900 SCT, 2300 BKN, vis 10+, which really means I can get in on the visual - but something doesn't smell right so I ask for the NDB. The controller clearly isn't happy, but I really don't like the fact that every time I check, the weather is something a little different. So I get PD to 3000, slide into the soup at about 4500, and at 3000 I can see down to the ground most of the time. I figure as soon as I drop down to 2600 after crossing the NDB, I'll be out of it and just ask for the visual. Well, I cross the NDB and drop to 2600, but now I'm in solid soup. So I figure it's just a bad patch, and as soon as I do the procedure turn and drop down, I'll be out. I'm still not really in hard IFR mode - not really in the game. My mindset is still in the "penetrate a cloud layer" rather than "shoot approach to minimums" mode. Well, I intercept inbound, drop to MDA - and I'm in and out of soup, and the only stuff I can see is straight down or nearly so. Visual aircraft control is impossible - I'm on instruments and diverting attention to look out. Now I realize I haven't briefed the miss because it never occurred to me I might have to miss from this approach - until now. I'm 3 miles from the airport and I can't see anything I recognize. So I quickly glance at the missed, and fortunately it starts with a straight climb to 2600 so I figure I'll have time to sort it out. NOW I'm in the game. I also realize it has been over eight months since my last recurrent training - I'm getting rusty. I should have snapped to this a lot quicker. My scan tightens up, and I concentrate on keeping the altitude dead on. I don't dare go below mins, and even 30 ft above makes a noticeable difference in the vis. Finally, about a mile from the airport, I spot the North hangars through the haze and mist. That tells me where the runways is, and I spot the REILs so now I'm golden. I make a descending right turn (still partially on instruments) and then a descending left turn (now visual), and fortunately I have a stiff headwind on final so I don't have to do anything really ugly to make the runway. On the ground, the visibility is 10+ miles. A CFI in a Cessna asks me where the bases are. I tell him right at mins, and I wasn't sure until the last minute whether I would get in or not, so he takes off for some VFR pattern work with a student. Automated weather claims 900 SCT, 2000 OVC, vis 10+. I look to the South of the airport. The clouds there are clearly higher and less solid, so I guess the weather station isn't broken. That's just the way it goes. What did that pilot see on the approach? How long had it been since his last recurrent training? All we can do is speculate. I once made an ILS approach that was advertised at 900 and 3 - and it was right at minimums, no ****, couldn't even see the approach lights until I was below 250 ft. An airliner came in behind me and reported the approach at mins. This wasn't some little podunk place, either - this was SHV, a major Class C regional like RDU. My guess is that the Mooney pilot encountered some conditions that were probably landable but more demanding than what he was expecting, and he never got his head back in the game. Michael |
F/A-22 Drops JDAM Successfully | Otis Willie | Military Aviation | 1 | September 15th 04 06:49 AM |
Mooney info | eddie | Owning | 13 | March 12th 04 06:42 PM |
Mooney 201 Insulated Engine Cover | Doug K | Owning | 0 | January 5th 04 02:44 AM |
Mooney to Offer Light Sport Airplane | Rick Pellicciotti | Home Built | 4 | September 24th 03 01:08 PM |
Cirrus vs Mooney | Charles Talleyrand | Owning | 6 | July 8th 03 11:35 PM |
