My low estimates were about $7000.
Then you should do it. Also, remember that it is "likely" that your aircraft will appreciate in value. While that isn't guaranteed,and should be treated as a bonus, it is highly probable. But the main reason to buy is that it changes your mission profile. Example - I used to rent, fly around for 90 minutes and land. It was never worth actually landing anywhere nearby, as my FBO charged 3 hours minimum if ever the aircraft was out over 3 hours, regardless of how long it flew. Now on a weekend, particularly a bad weather one, I'll fly 30 minutes to an airport where I will land, meet several friends, have coffee and BS for an hour, then fly toward home for 15 minutes, land and do it again, then fly home. Total flight time less than 60 minutes. Total time - all day. Total aviation value - priceless. Total cost - Variable costs $30.00. Fixed costs I pay whether I fly or not. So now I fly lots. Like you I agonized over the cost. Once I bought I kicked myself for not doing it a long time ago. And as an aside, there is a certain comfort in always finding the plane as you left it, with your stuff in it, and knowing that it wasn't abused on its last flight. My advice is to do it - you'll find many benefits that you hadn't even considered. Tony Tony Roberts PP-ASEL VFR OTT Night Almost Instrument ![]() Cessna 172H C-GICE |
Thanks Tony,
This is exactly the kind of thing I've been agonizing about, too. Not just day trips, but what if I want to take a two or three hour trip to see friends, and then stay for a week? I don't want to pay a three hour per day minimum for seven days, when the plane will probably only fly six hours total! Thanks! |
The Weiss Family wrote:
This is exactly the kind of thing I've been agonizing about, too. Not just day trips, but what if I want to take a two or three hour trip to see friends, and then stay for a week? I don't want to pay a three hour per day minimum for seven days, when the plane will probably only fly six hours total! Again, if money is an issue, look at buying your first plane with a partner. You'll have someone else to share the initial cost, the ongoing work and fixed expenses, and if your partner is more experienced with planes, you'll also be able to avoid a lot of the expensive, newbie-owner mistakes that I (and probably many others) make. If you're at all serious about travelling, renting isn't a realistic option. I wasn't able to find a partner around Ottawa when I was first looking (I cared about IFR and the other people I talked to didn't want to spend the extra money), and I'm managing OK as a sole owner now, but the first 18 months or so were a little hairy. If you can remember what it was like when you moved from an apartment to your first house (as owner), and suddenly you were expected to know about how to deal with contractors, what quotes were fair, what weeping tiles were, how to grade a lawn, building codes, property taxes, etc. etc., you'll have a good idea of what it will be like at first owning a plane -- just multiply all that by 10. When you're getting close to buying, come back to the list and you'll be able to find a lot of advice (more than half of it good). Here are a few easy, generic checklist items for any kind of plane: 1. How much weight can it carry with full fuel? How about with fuel at tabs? Is that enough for your family now? What about three years from now? Since you have a family, useful load probably matters more than speed. Flying with fuel at tabs might not be practical for IFR, with the requirement for an alternate and extra reserves, so pay close attention to the full-fuel load if you're an IFR pilot or are likely to become one soon. 2. How many recurring ADs are there for the make/model, and how much do they cost to carry out? For example, an older Cherokee with a front-mounted oil cooler will need to have its oil hoses replaced every 8 years, which is only a couple of hundred dollars; other recurring ADs, however, can cost thousands. Don't wait until you've already put down a deposit and paying for a prepurchase inspection to find out about these, since you can easily research them online from your desk while leafing through Trade-a-Plane. 3. What avionics do you need? It's a *lot* (ie. 50%-75%) cheaper to buy a plane with the avionics you need already installed than to buy and install them afterwards. If you fly IFR and think you're going to want a Stormscope, autopilot, and/or IFR GPS, look at planes that already have those (personally, all I really wanted for IFR beyond basic NAV/ADF/DME was a Stormscope, which I had installed last month). 4. How close is the engine to TBO? Most people seem to prefer an engine that is about 50% of the way along -- that way, any problems from the last overhaul are already worked out, but you still have a long time until the next one. The plane's price will be adjusted accordingly. 5. Have fun looking. All the best, David |
David is exactly right about finding the right plane, my first plane (a cherokee
180), I ended up putting all kinds of speed mods on it, new avionics, then decided it was not fast enough so bought my current plane a Turbo Arrow, this time I got a plane that had things I wanted in it, HSI, airconditioning, some speed mods, really good interior and paint. I did how ever still spend about 20k for new garmin 430, audio panel, xponder and AM/FM/CD player for the wife to listen to on those long trips. the good thing about owning your own plane is your not restricted to anything except weather and deciding where you want to go next. David Megginson wrote: The Weiss Family wrote: This is exactly the kind of thing I've been agonizing about, too. Not just day trips, but what if I want to take a two or three hour trip to see friends, and then stay for a week? I don't want to pay a three hour per day minimum for seven days, when the plane will probably only fly six hours total! Again, if money is an issue, look at buying your first plane with a partner. You'll have someone else to share the initial cost, the ongoing work and fixed expenses, and if your partner is more experienced with planes, you'll also be able to avoid a lot of the expensive, newbie-owner mistakes that I (and probably many others) make. If you're at all serious about travelling, renting isn't a realistic option. I wasn't able to find a partner around Ottawa when I was first looking (I cared about IFR and the other people I talked to didn't want to spend the extra money), and I'm managing OK as a sole owner now, but the first 18 months or so were a little hairy. If you can remember what it was like when you moved from an apartment to your first house (as owner), and suddenly you were expected to know about how to deal with contractors, what quotes were fair, what weeping tiles were, how to grade a lawn, building codes, property taxes, etc. etc., you'll have a good idea of what it will be like at first owning a plane -- just multiply all that by 10. When you're getting close to buying, come back to the list and you'll be able to find a lot of advice (more than half of it good). Here are a few easy, generic checklist items for any kind of plane: 1. How much weight can it carry with full fuel? How about with fuel at tabs? Is that enough for your family now? What about three years from now? Since you have a family, useful load probably matters more than speed. Flying with fuel at tabs might not be practical for IFR, with the requirement for an alternate and extra reserves, so pay close attention to the full-fuel load if you're an IFR pilot or are likely to become one soon. 2. How many recurring ADs are there for the make/model, and how much do they cost to carry out? For example, an older Cherokee with a front-mounted oil cooler will need to have its oil hoses replaced every 8 years, which is only a couple of hundred dollars; other recurring ADs, however, can cost thousands. Don't wait until you've already put down a deposit and paying for a prepurchase inspection to find out about these, since you can easily research them online from your desk while leafing through Trade-a-Plane. 3. What avionics do you need? It's a *lot* (ie. 50%-75%) cheaper to buy a plane with the avionics you need already installed than to buy and install them afterwards. If you fly IFR and think you're going to want a Stormscope, autopilot, and/or IFR GPS, look at planes that already have those (personally, all I really wanted for IFR beyond basic NAV/ADF/DME was a Stormscope, which I had installed last month). 4. How close is the engine to TBO? Most people seem to prefer an engine that is about 50% of the way along -- that way, any problems from the last overhaul are already worked out, but you still have a long time until the next one. The plane's price will be adjusted accordingly. 5. Have fun looking. All the best, David |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Annual Cost of Ownership | Tom Hyslip | Owning | 6 | March 3rd 04 01:24 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
