cost of ownership
Old May 23rd 04, 10:47 PM
Jeff
when I bought my current plane, I went after a low time factory reman. engine.
Any engine with over 600 hours on it (I have a 1800 hr TBO on my engine) I would
not even look at, but I was seeing planes with engine at or close to TBO where
the owners wanted the same price as one with a new engine.
when I did the prebuy, I also had an oil analysys done to make sure the engine
was still in good shape.
David Megginson wrote:
The Weiss Family wrote:
Ouch!
I definitely couldn't afford that right away on top of all the other
expenses.
This limits the field of potential aircraft to low-time (or mid-time)
engines.
Not necessarily -- if the market is working correctly, the difference
between the cost of a plane with a new engine and a plane with a run-out
engine should be about equal to the cost of an overhaul.
From what I've seen on these lists and heard talking to other pilots,
low-time engines can be a bad idea, especially if the previous owner did a
quick, cheapie overhaul to help sell the plane. Doing your own overhaul on
a run-out engine is probably better, but you're assuming the risks of all
the early problems that show up afterwards. I chose mid-time, and I've been
very happy with that.
All the best,
David
Old May 24th 04, 02:40 AM
Newps
"Jeff" wrote in message
engine.
Which makes no sense as it has a Continental. The last thing I want is
Continental jugs. Chromed Continental cylinders would be OK.
Old May 24th 04, 07:26 AM
Jeff
makes no sense to you, makes sense to me since I am the one payig the bills
for it.
I would buy a plane with a factory reman before I bought one with a who
knows what kind of overhaul.
engine.
Old May 24th 04, 03:20 PM
Newps
bills
for it.
Must be your first Continental. Those of us that have Continentals know not
to get a factory engine. The bottom ends are great, but the cylinders are
crap.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Annual Cost of Ownership Tom Hyslip Owning 6 March 3rd 04 01:24 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
