Survey: which business
Old May 27th 04, 02:32 PM
Nathan Young
On Tue, 25 May 2004 13:38:50 GMT, Smutny
On Tue, 25 May 2004 06:14:55 -0700, "Tom Sixkiller"
"Smutny" wrote in message
My current business has no need for travel other than annual
conventions. However, I'm looking at puchasing a company that writes
software for municipalities, so I see a definate possibility of using
a plane to visit cities around the state.
How about around the region?
Yes, there are some neighboring states that have a right structure
that make them possible customers. But I'd be speaking out of turn to
say that they're a definate market without more research.
One question I have that I don't recall ever seeing discussed here...
When you purchase a plane for business use, can it be a homebuilt?
It can be whatever you want, though the IRS might look askew at you when you
put stuff on your tax return.
I suppose the IRS has some documentation one what they want. Anyone
know the document numbers?
For instance, a RV-6/7 would be an ideal platform for buzzing around
the state visiting customers.
And limiting your business too much.
An RV has the performace to easily reach out to the region.
To get similar performance out of a
production airplane I'd be looking at well over twice the cost.
How's it's reliability? Are you willing to cancel appointments? Critical
ones, such as closure meetings?
Sounds like (I maybe wrong) you're fitting your business to match your
aircraft whims, rather than your aircraft SPECS to match your business
needs.
Not really. The business is established and ripe for expansion. Yes
I do have a real soft spot for the RV series. However; to get the
same speed and range, one would have to look at a SR20 or retract
single. Even an older 182RG costs (initial and maintenance) are well
above a RV.
As far as reliablity, spending the time to find a well built example,
and utilizing the expertise of a trusted builder to help with the
purchase, I have no doubt that reliability will meet or exceed a
production single.
I own a homebuilt now, and it is has be the most reliable airplane
I've ever flown.
I've never flown in an RV, so I have to ask this question: Do they
have sufficient baggage area to use effectively for business? Sure
most of us only require a suitcase, laptop, and projector these
days... I just imagine stuffing more than that in an RV would be
difficult.
Old May 27th 04, 10:34 PM
Bob Martin
difficult.
The baggage area is a pretty good size; you could get more than that
inside it. Maybe two suitcases if they aren't too big, or definately
2-3 duffel bags, a tent, and your laptop. And if you don't have to
take a passenger along, you can remove the seat back and lay things
down in there too. Some guys have even made modifications to the aft
bulkhead (extending the baggage compartment some more) so they can
carry their golf clubs with them. But yes, the things you mentioned
above would fit comfortably, at least in a 6/7/9. The 10 has even
more room, being a 4-seater and all.
I know a guy that used to use his -6A for business; he was a state
representative and used it to fly from his home district to our
airport near the state capitol.
As far as costs, an RV-6/7 would run about 45-50k to build yourself.
Not sure what they go for completed. If you build it yourself, you
can do your own annuals, and I'm not sure how much of the maintenance
you can do if you aren't the "primary builder."
Old May 28th 04, 02:43 AM
Smutny
On 27 May 2004 14:34:34 -0700, (Bob Martin)
difficult.
Yeah, I've seen some RV-6's in the $50K-$60K neighborhood, but they
usually have O-320's and are VFR only. To get a well built RV with an
O-360 and IFR capability, you're looking at $100,000+.
As far as building vs. buying... It's 6 of one, half dozen of the
other. Either you spend more money with annuals or you spend more
time up front building. I'm more of a pilot than a builder, I'll buy
my time with paying more for a nice, ready to fly, airplane.
-j-
Old May 28th 04, 02:39 AM
Smutny
On Thu, 27 May 2004 13:32:46 GMT, Nathan Young
needs.
above a RV.
production single.
I've ever flown.
difficult.
That's one of the points that makes the RV-7 so attractive to me. The
RV-3 & -4 don't have much space, but those are older models. Even the
tandem -8 has two storage areas.
-j-
questions on business use of my personal aircraft Bob Owning 14 May 4th 04 06:11 PM
Associate Publisher Wanted - Aviation & Business Journals Mergatroide Aviation Marketplace 1 January 13th 04 08:26 PM
Associate Publisher Wanted - Aviation & Business Journals Mergatroide General Aviation 1 January 13th 04 08:26 PM
SIFL Tax question for small business owners Dave Owning 4 August 24th 03 02:43 PM
Business Aircraft & Jet Preview - Denver, CO - August 6, 2003 Mergatroide Aviation Marketplace 0 July 21st 03 05:36 PM
