slightly high aluminum in an IO-360
Old May 27th 04, 04:42 PM
Orval Fairbairn
"G.R. Patterson III" wrote:
"Robert M. Gary" wrote:
I'm sure the shop is doing it but I do most of the oil changes myself
(except the one at annual). I'm not checking the screen.
I check mine every other oil change, whether I've run up 50 hours or not. My
engine
is an O-320. On that, the screen looks like a horizontal drain plug on the
sump.
Safety-wired, of course.
George Patterson
None of us is as dumb as all of us.
I check mine every oil change (25 hr) AND, I have a niobium magnet in
each drain plug, to collect all ferrous metals.
IMHO, the magnet asved my plane (possibly my life) a couple of years
ago, when I found some flattened pieces of steel, anout .05" across.
They were coming from the big roller bearing that serves as a thrust
bearing -- its cage had broken and it was making some noises which I
could hear at idle.
The steel drain plugs are the perfect place to put one or two of these
magnets, as they are self-attaching.
Old May 27th 04, 05:24 PM
G.R. Patterson III
I replaced my drain plug with a quick-drain. That would certainly complicate using
the magnets on my aircraft.
George Patterson
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
