![]() "Steven P. McNicoll" wrote in message nk.net... "Dude" wrote in message ... Not true at all. Of course it's true. Why do you say it isn't? Every pilots' number one responsibility is safety. If I am flying a commercial plane, and get warning of traffic on my course, I really have NO choice but to accept vectors or other avoidance measures. It's been my experience that very few commercial planes request vectors around VFR targets which they've been advised of. Approach: Lear 1234 VFR traffic your 12 o'clock same altitude, same heading, 5 miles, do you see them? Lear: No Visual Approach: Lear 1234 - Immediate right turn to 090. Lear: ??????? You propose to ignore this warning? The VFR pilot is oblivious to the fact that he is about to get squished by the ridiculously fast jet traffic, and has no way to avoid it. He can't see it? Even if he is trying, he may not see it, its going 350 knots straight at him, maybe from behind. Even if an IFR plane is right on altitude, he will be blamed for the midair if he fails to avoid the traffic. No more so than the other participant in the midair. I would not make that bet. The IFR traffic has been told to change course by ATC to avoid a possible mid air. The VFR pilot could be flying perfectly legally. On the other hand, when VFR pilots use radar service, they almost always voluntarily comply with altitudes and vectors rather than drop radar service. That allows the IFR pilot, and the airlines, to continue through like they own the place. Comply with altitudes and vectors? What altitudes or vectors would there be for them to comply with? Yes, even outside the class B, I have been assigned altitude and vectors by ATC to avoid VFR and IFR traffic. I once had a VFR plane coming right at me, and the controller's voice had enough fear in it that you would have thought he was in the plane with me. He did not vector me around it, I told him I was changing course, but I have had my altitude and vector changed to avoid possible conflicts. Which apparently the airlines have gotten all to used to. GA's use of the system improves the cost of operations for the airlines, not the other way around. You have a poor understanding of the system. On what do you make this assumption? I will be at the FSDO tomorrow, should I as them a question for you? |
![]() "Dude" wrote in message ... Every pilots' number one responsibility is safety. That's swell, but it doesn't answer my question. Approach: Lear 1234 VFR traffic your 12 o'clock same altitude, same heading, 5 miles, do you see them? Lear: No Visual Approach: Lear 1234 - Immediate right turn to 090. Lear: ??????? You propose to ignore this warning? What do mean by "this warning"? The traffic advisory or the improper ATC instruction? The traffic is five miles away and moving in the same direction, there's certainly no imminent threat. Even if he is trying, he may not see it, its going 350 knots straight at him, maybe from behind. So what prevents the Lear from spotting the traffic? I would not make that bet. The IFR traffic has been told to change course by ATC to avoid a possible mid air. The VFR pilot could be flying perfectly legally. What bet? Does IFR traffic have a greater responsibility than VFR traffic to see and avoid other traffic? Why do you have the controller issuing improper instructions in your scenario? Yes, even outside the class B, I have been assigned altitude and vectors by ATC to avoid VFR and IFR traffic. I once had a VFR plane coming right at me, and the controller's voice had enough fear in it that you would have thought he was in the plane with me. He did not vector me around it, I told him I was changing course, but I have had my altitude and vector changed to avoid possible conflicts. ATC can issue headings and altitudes to VFR aircraft in Class B and Class C airspace, in the outer area associated with Class C airspace, and in a TRSA. Nowhere else. On what do you make this assumption? From your statements. I will be at the FSDO tomorrow, should I as them a question for you? I have no questions on this subject. |
You apparently think you know everything, and are being argumentative and
obtuse. I am not getting anything from this anymore, and I am done. I will talk to the guys at the FSDO, and maybe I will learn something there. "Steven P. McNicoll" wrote in message nk.net... "Dude" wrote in message ... Every pilots' number one responsibility is safety. That's swell, but it doesn't answer my question. Approach: Lear 1234 VFR traffic your 12 o'clock same altitude, same heading, 5 miles, do you see them? Lear: No Visual Approach: Lear 1234 - Immediate right turn to 090. Lear: ??????? You propose to ignore this warning? What do mean by "this warning"? The traffic advisory or the improper ATC instruction? The traffic is five miles away and moving in the same direction, there's certainly no imminent threat. Even if he is trying, he may not see it, its going 350 knots straight at him, maybe from behind. So what prevents the Lear from spotting the traffic? I would not make that bet. The IFR traffic has been told to change course by ATC to avoid a possible mid air. The VFR pilot could be flying perfectly legally. What bet? Does IFR traffic have a greater responsibility than VFR traffic to see and avoid other traffic? Why do you have the controller issuing improper instructions in your scenario? Yes, even outside the class B, I have been assigned altitude and vectors by ATC to avoid VFR and IFR traffic. I once had a VFR plane coming right at me, and the controller's voice had enough fear in it that you would have thought he was in the plane with me. He did not vector me around it, I told him I was changing course, but I have had my altitude and vector changed to avoid possible conflicts. ATC can issue headings and altitudes to VFR aircraft in Class B and Class C airspace, in the outer area associated with Class C airspace, and in a TRSA. Nowhere else. On what do you make this assumption? From your statements. I will be at the FSDO tomorrow, should I as them a question for you? I have no questions on this subject. |
![]() "Dude" wrote in message ... You apparently think you know everything, and are being argumentative and obtuse. Obtuse is the exact word I was thinking of when reading Steven's posts. I don't believe he was always this way, it just started with the Rutan space thread. Perhaps he should get in for a thorough check-up? Allen |
![]() "Allen" wrote in message m... Obtuse is the exact word I was thinking of when reading Steven's posts. In what way do you think I've been obtuse. I don't believe he was always this way, it just started with the Rutan space thread. If you check the statements I made in that thread you will find them all to be correct. |
![]() "Steven P. McNicoll" wrote in message news ![]() "Allen" wrote in message m... Obtuse is the exact word I was thinking of when reading Steven's posts. In what way do you think I've been obtuse. I don't believe he was always this way, it just started with the Rutan space thread. If you check the statements I made in that thread you will find them all to be correct. Nothing personal, it just seems you are perfecting the art of answering a question with a question. |
![]() "Allen" wrote in message m... Nothing personal, it just seems you are perfecting the art of answering a question with a question. Actually, I believe that was Socrates. |
![]() "Dude" wrote in message ... You apparently think you know everything, and are being argumentative and obtuse. No, I don't know everything, but I do know everything about the subject we're discussing. I am not getting anything from this anymore, and I am done. I don't think you've tried to get anything from this. I will talk to the guys at the FSDO, and maybe I will learn something there. What will you ask the guys at FSDO? |
1965 Cessna P206 - 1/3rd Share - Centennial Airport (APA), Denver, CO | Shawn | Aviation Marketplace | 0 | September 16th 04 08:54 PM |
NWA CEO Richard Anderson says GA not paying it's fair share | Bela P. Havasreti | Owning | 4 | March 16th 04 04:27 PM |
Partnership......share | Jurgen | Owning | 0 | February 13th 04 02:35 AM |
How does one purchase a share in an LLC which owns an airplane? | Shawn | Owning | 2 | November 19th 03 01:48 PM |
Fair Tribunals at Guantanamo? (Was: YANK CHILD ABUSERS :: another reason to kill americans abroad ???) | Henrietta K Thomas | Naval Aviation | 207 | August 11th 03 09:23 PM |
