Garmin 296 and FliteStar
Old June 2nd 04, 07:40 AM
C J Campbell
"Rich Raine" wrote in message
I recently bought a Garmin 296 and found I can not upload route or data
from
the 296 to Flitestar.
You may need to change the transfer setting on the GPS from "Advanced NMEA"
to "NMEA," or vice versa.
The manual that Garmin wrote for this unit is despicable. You can't find
anything in it. The manual also contains several inaccuracies.
The 296 itself is beautiful, light weight, and it works very well. It is
missing a few features the 295 had, notably the RMI indicator option. I am
getting about 7 hours of battery life out of a charge.
Old June 2nd 04, 03:41 PM
John Bell
CJ,
I don't have a 296, just a 196. However, I have played with the 296. If
you go to the HSI page and press menu, you can change the HSI BUG to
indicate BEARING. This essentially gives you an RMI and HSI combined into
one. If I remember correctly the pointer on the EFIS option is BEARING,
which makes it a big RMI for the arc that it covers.
John Bell
www.cockpitgps.com
Old June 3rd 04, 02:31 PM
Dan Luke
despicable. You can't find anything in it. The
My big complaint is that I cannot slew the map pointer to an airport and
create a user waypoint on a runway as I could with the 295. If I try,
the 296 will simply create another waypoint at the airport datum point.
One of my favorite tricks with the 295 was creating a waypoint at the
approach end of a runway, selecting "direct" to the point and setting
the GPS OBS for runway heading. This gave me an extended runway
centerline that was helpful with visual approaches. Can't do it with
the 296 unless I'm sitting on the runway.
Another thing: the flight recorder feature has a bug in it that causes
it to record spurious landings. For example, when I flew from Mobile to
Pinckneyville, IL it said I made 10 landings enroute. On almost every
flight it has recorded phantom landings. Garmin says this is due to
momentary loss of satellite reception, but I doubt it. I've kept a
watch on the GPS status page and never seen fewer than six strong
satellites.
Dan
C172RG at BFM
