Advice on buying a 152?
Old June 15th 04, 06:37 PM
Dave Butler
The lease back options leave you open for all kinds of
expenses and you have to pay insurance, etc.
How many leased-back airplanes have you owned, then?
Old June 17th 04, 02:15 AM
Greg Hopp
Dave Butler wrote in message
I own a C-150 with a patient, understanding partner. BOth of us are
new to the experience. It has worked out great so far, both of us are
on the same wavelength. I am trying to figure out why a lease-back
would work. The importance of ownership (to many) is that the plane
is as you left it, or as your partner left it. Since both of you own
a stake in the plane, it is well taken care of.
With a leaseback, you are another renter, but different in that you
bear the burden of all the expense, annual, 100 hr inspections,
break/fix, etc. and you still don't get to take it when you want to.
Where is the advantage to that?
In my experience as a first time owner, having a partner or three to
divide the expenses (and there ARE expenses) has made the experience,
overall, wonderful.
Best,
Greg H.
N4691X
'67-G
Old June 17th 04, 03:41 AM
G.R. Patterson III
The terms of leases vary. You may indeed bear all these expenses; if so, you also get
the lion's share of the rental proceeds. In some leases, the FBO pays all the
expenses and you get a small part of the rental proceeds. In either case, your income
from rental is the "advantage to that"; you are indeed just another renter when it
comes to flying the plane.
Ron Natalie used to point out that a leaseback is a business, and you should treat it
as one. If you do that, the plane is just a business asset and you're likely to make
money at it. If you lease your aircraft out as a way to make the payments on "your
baby", the results will not please you.
George Patterson
None of us is as dumb as all of us.
Old June 17th 04, 03:11 PM
Dave Butler
My question above was directed to a poster who seemed to be expressing an
opinion based on no experience. Since he didn't respond, I'm guessing -his-
answer would be -none-.
With a leaseback, you are whatever the terms of the lease say you are. You are
responsible for whatever the terms of the lease say you are responsible for. You
can take it whenever the terms of the lease say you can take it. If you don't
like the terms of the lease, don't sign it.
Assume for a minute that the terms are those that you assume in the previous
paragraph. The advantage might be that you gain experience in aircraft ownership
while reducing your out-of-pocket expense. Your aircraft gets flown, instead of
sitting on the ramp corroding. The fixed costs of tiedown, insurance, annual
inspections, etc are amortized over a larger usage base, lowering your hourly
cost. I'm sure you can think of more. Heck, it's even possible to come out
financially ahead. There are lots of people with different goals and different
expectations. Some will see an advantage in a lease, and some won't.
overall, wonderful.
I've had two partnership experiences, one excellent, one troublesome.
Dave
Old June 17th 04, 11:33 PM
Michael
I've never owned a leased-back plane. Until fairly recently, I've
never had a root canal done either. However, I know quite a few
people who have owned leasebacks. I also know quite a few people who
had root canals done. Interestingly, my impression of what it was
like to get a root canal wasn't really changed much by having one -
the impression I got from my friends was pretty accurate. It was
painful and expensive, as are most root canals, and to be avoided if
possible. Much the same applies to leasebacks.
If you don't like the terms of the lease, don't sign it.
True but disingenuous. You are highly unlikely to get favorable
terms.
The reality is that there isn't much (if any) money to be made in
airplane rental. The money is made by selling fuel, maintenance,
tiedown/hangar space, and maybe instruction. The rental airplanes are
just there to keep the business going.
Untrue. The only experience in aircraft ownership you will gain is
the experience of writing checks. You will be paying huge money for
insurance that allows rental. This can easily double or triple your
fixed costs. Of course that means the plane has to keep flying to
generate revenue, and that means you can't wait until you have time to
fix it yourself. The result is that you don't actually learn to fix
anything - which is the most important part of gaining experience in
aircraft ownership.
Heck, it's even possible to come out financially ahead.
I suppose it might be possible. I've never seen it happen.
I've seen the occasional mechanic who did all or almost all his own
maintenance come out ahead - by assuming his time was worth nothing.
I have NEVER seen a first-time owner come out ahead on a leaseback.
My point is not that it's impossible to have a good experience with a
leaseback - but anyone who has to ask about it on the net is not going
to have a good experience, and that's certain.
Michael
Old June 18th 04, 03:51 PM
Dave Butler
terms.
I don't take kindly to being called disingenuous. Let's elevate this discussion
above name-calling, OK? You've made a lot of valuable contributions to this
group, Michael, but calling people disingenuous because they don't agree with
your position is not a positive contribution.
I stand by my position. You're not likely to get favorable terms if you just
accept the terms that are offered. You're free to negotiate any terms you like.
If you don't get what you want, you are free to walk away.
airplane rental.
Quite true.
....and this is based on your experience of -no- leasebacks?
fixed costs.
That's why you collect rent for the use of your aircraft. Assuming, of course,
that your lease contract requires -you- to pay for the insurance.
aircraft ownership.
.... in your opinion.
Old June 18th 04, 07:20 PM
Michael
terms.
Point taken, and I apologize. However, I still don't agree that it is
possible for the owner of a single airplane to get favorable leaseback
terms from an FBO, especially a first time buyer. The only people
I've ever heard claim otherwise were those who benefit by leasebacks
and those who haven't tried but believe it can be done. If you have a
specific counterexample, I would love to hear about it.
Doesn't quite work that way. Nobody will sign a leaseback contract
with you for an airplane you don't own. Once you've invested the
capital, you are indeed free to walk away - but you've already
invested the capital.
airplane rental.
Quite true.
Then what makes you believe a leaseback can work? If there isn't
money to be made there, then how are you to make money there?
No, it's based on the experience of my friends who tried.
It's like that root canal thing.
And what is your experience with leasebacks?
Michael
Old June 19th 04, 02:38 AM
G.R. Patterson III
An aquaintance of mine had several aircraft on leaseback at Kupper airport through
the 90s. The terms of the lease were that he provided the plane and the FBO performed
and paid for all maintenance and provided insurance. He got something like $10/hour
from the rent. At one time, he had three older 172s on lease. His worst experience
was when a student wrinkled a firewall. That plane was down for 6 weeks, producing no
income, but it was the FBO that had to swallow the repair bill.
He banked most of the rental money. As each engine hit TBO, the plane was upgraded to
180 hp (at the owner's expense) and the rent was increased. His portion of the rent
also increased, of course. As the rental income accumulated, he had each aircraft
painted. The next step was to fix up the interior. At that point, he would have the
FBO restrict the rental to moderate time pilots who could be expected to treat the
planes well. Eventually he pulled each aircraft off the line and sold it for
considerably more than he had invested. In at least one case, he sold the plane as
soon as he finished the interior work. I think he did not have any avionics
improvements made.
He retired to Carolina last year. Dunno whether he sold the last one or took it with
him, but he had sure turned it into a good-looking plane last time I saw it.
George Patterson
Old June 21st 04, 01:58 PM
Dave Butler
Michael wrote:
terms.
Apology accepted.
OK, my successful counterexample is from my own experience, which I have
described previously in this forum (google is your friend), but I'll briefly
describe it again. See below. My lease was not to an FBO, so I guess you can
argue it is not a "leaseback", but just a "lease". In common aviation usage,
this sort of lease is commonly referred to as a leaseback.
I agree. I was assuming you already owned the aircraft, which is not the OP's
situation.
airplane rental.
Quite true.
You said not much, not none. I agree the margins are thin and the risks are high.
I owned a PA28-180, leased to a flying club, for -I don't know- several years,
long enough to go through 2 engine overhauls on it. I started out with a
partner, ended up as sole owner. The aircraft was used by a flying club for
instrument training and whatever club member do with airplanes, no primary
training. I used 350 hours / year as a planning number.
After sale of the aircraft and recapture of the depreciation, I made a small
amount. You could argue that the amount I made was not worth the amount of risk
in the investment, and I'll certainly stipulate that I was lucky. There were
intangible benefits that made it worth it to me. I did -none- of my own
maintenance, so by your criteria, I guess I learned nothing from the exercise. I
don't feel that way about it, though.
Incidentally, this same aircraft was sold to another club member, who also
leased it to the same club. Not sure, but I think her lease experience was not
as positive as mine. It's now been sold to yet another club member, who
continues to lease it to the club. The current owner is a friend and coworker
and comments positively about the status of the business, but I haven't examined
his books.
Dave
Seeking advice on pilot training approach... Rob General Aviation 8 December 15th 04 12:58 AM
Tips on buying a cessna 182 Matteucci Aviation Marketplace 4 September 15th 04 08:42 AM
"Why Raptor? The Logic of Buying the World's Best Fighter" Mike Military Aviation 0 August 11th 04 03:20 PM
boot camp advice jameson Military Aviation 17 July 22nd 04 05:12 AM
Advice request -- buying an airplane Casey Wilson Owning 4 April 19th 04 03:22 PM
