I've just bought myself a new Garmin handheld GPS. I noticed that the auto
dash mount is stuck to the dashboard with some kind of double-stick stuff. Is it OK by the FAA to stick the mount onto my airplane's glare shield this way, or do they consider it a permanent installation and require 337s and stuff? What about using strong Velcro? Will that pass muster with the FAA as a temporary installation? Henry |
![]() "Henry Kisor" wrote in message ... I've just bought myself a new Garmin handheld GPS. I noticed that the auto dash mount is stuck to the dashboard with some kind of double-stick stuff. Is it OK by the FAA to stick the mount onto my airplane's glare shield this way, or do they consider it a permanent installation and require 337s and stuff? What about using strong Velcro? Will that pass muster with the FAA as a temporary installation? I've used velcro for my Garmin Pilot III for the last 5 years. I also hardwired it into the aircraft. Couldn't possibly care less what the FAA thinks. |
You have an experimental or certified, newps?
Newps wrote: "Henry Kisor" wrote in message ... I've just bought myself a new Garmin handheld GPS. I noticed that the auto dash mount is stuck to the dashboard with some kind of double-stick stuff. Is it OK by the FAA to stick the mount onto my airplane's glare shield this way, or do they consider it a permanent installation and require 337s and stuff? What about using strong Velcro? Will that pass muster with the FAA as a temporary installation? I've used velcro for my Garmin Pilot III for the last 5 years. I also hardwired it into the aircraft. Couldn't possibly care less what the FAA thinks. |
Dave S wrote:
You have an experimental or certified, newps? Newps wrote: "Henry Kisor" wrote in message ... I've just bought myself a new Garmin handheld GPS. I noticed that the auto dash mount is stuck to the dashboard with some kind of double-stick stuff. Is it OK by the FAA to stick the mount onto my airplane's glare shield this way, or do they consider it a permanent installation and require 337s and stuff? What about using strong Velcro? Will that pass muster with the FAA as a temporary installation? I've used velcro for my Garmin Pilot III for the last 5 years. I also hardwired it into the aircraft. Couldn't possibly care less what the FAA thinks. Amen ! |
![]() "Dave S" wrote in message news ![]() You have an experimental or certified, newps? I have a 182. You can't possibly be worried about velcro fer cryin' out loud, can you? For the power I took the cig lighter plug and snipped off the cig lighter end. Ran the two wires into the electrical bus and used a 1 amp fuse from Rat Shack. Had the mechanic sign off the power cord. My setup is neat looking because I have an avionics access panel on the top of the glareshield. The cord just disappears down there from behind the GPS, you don't even see it from the pilots side. |
"Newps" wrote, "... I have an avionics access panel on the top of the
glareshield." Please tell me more. I have a 182Q. Did you create the access panel yourself? Regards, Jon |
![]() "Jon Woellhaf" wrote in message news:zv8Ac.62220$HG.3470@attbi_s53... "Newps" wrote, "... I have an avionics access panel on the top of the glareshield." Please tell me more. I have a 182Q. Did you create the access panel yourself? No, I assumed it was standard for my year. I have a 67 182K. The panel is about 12 inches wide and about 8 inches front to back. Held down with about 12 little sheet metal screws. |
Newps wrote:
: amp fuse from Rat Shack. Had the mechanic sign off the power cord. My : setup is neat looking because I have an avionics access panel on the top of : the glareshield. The cord just disappears down there from behind the GPS, : you don't even see it from the pilots side. I also have an avionics access panel in the top right side of the glareshield of my Cherokee. I ran my GPS power cord through this opening, as well. It looks very neat, the cord stays out of the way if I don't want to use the GPS, and you don't see the cord at all. I glued velcro to the top of the glareshield to hold my GPS (295) because the extra weight on the yoke annoys my autopilot. The whole setup is very nice, IMHO. -- Aaron Coolidge (N9376J) |
Yeah, but what happens if you get ramped? That's my concern.
"Newps" wrote in message ... "Henry Kisor" wrote in message ... I've just bought myself a new Garmin handheld GPS. I noticed that the auto dash mount is stuck to the dashboard with some kind of double-stick stuff. Is it OK by the FAA to stick the mount onto my airplane's glare shield this way, or do they consider it a permanent installation and require 337s and stuff? What about using strong Velcro? Will that pass muster with the FAA as a temporary installation? I've used velcro for my Garmin Pilot III for the last 5 years. I also hardwired it into the aircraft. Couldn't possibly care less what the FAA thinks. |
On Wed, 16 Jun 2004 07:44:30 -0500, "Henry Kisor"
wrote: Yeah, but what happens if you get ramped? That's my concern. IF you get ramped and IF the inspector thinks the mount is permanent grab it with both hands and rip it off. The 2 sided tape isn't that strong that it can't be removed. I think they probably see an awful lot of these mounts and won't be concerned about it. Better to have it firmly attached than flying around the cockpit in turbulance. "Henry Kisor" wrote in message ... I've just bought myself a new Garmin handheld GPS. I noticed that the auto dash mount is stuck to the dashboard with some kind of double-stick stuff. Is it OK by the FAA to stick the mount onto my airplane's glare shield this way, or do they consider it a permanent installation and require 337s and stuff? |
Upgrade handheld GPS, or save for panel mount? | [email protected] | Owning | 7 | March 8th 04 03:33 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
FS: GPS - Handheld II Morrow - Apollo 920 Moving Map | ft worth | Aviation Marketplace | 0 | February 28th 04 08:33 PM |
Handheld GPS For Auction | ecktoeman | Aviation Marketplace | 0 | July 28th 03 09:07 PM |
FS: GPS - Handheld II Morrow - Apollo 920 Moving Map | NRH, Texas | Aviation Marketplace | 0 | July 24th 03 06:47 PM |
