Because if you call the FAA they'll tell you they need certification,
rather than spoil our horologists, let everyone else ask themselves the question of whether or not they're going to put that clock back into the panel of their certificated aircraft after they get it up and running properly. I know I absolutely would never do such a thing, the aircraft may fall out of the sky trying to give time! So for me there is no need to worry about any jerkie certification. The moronic thing is that a CRS will send him clocks to repair and they'll mark them up 5 or 6 times and sell them with a cert. On Wed, 16 Jun 2004 08:13:53 -0700, Jim Weir wrote: Ask YOURSELF the question ... where are the requirements for a clock to have some sort of certification? Last I looked, the only requirements were for the clock to have a "sweep second hand", which has later been interpreted to be a digital readout of seconds. Ask YOURSELF the question ... where in the regulations is the definition of "certified" for ANY application. Jim (COUGARNFW) shared these priceless pearls of wisdom: - -Ask the question, just that, on this forum: Which airplanes must have a -certified clock? Instrument flying would be my guess, but ask. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
![]() Stu Gotts wrote: Because if you call the FAA they'll tell you they need certification, That's not true. There are several battery-powered clocks which are not "certified" that directly replace the old windup models. The only time certification issues come into play is if you tie into the aircraft electrical system. Even that may not be true in all FSDOs (but it is with the clowns at Teterboro). George Patterson None of us is as dumb as all of us. |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
