Cessna 210 charging problem
Old July 8th 04, 06:57 AM
John
Most of the 24 volt Cessna's have the over voltage relay built into
the regulator. The over voltage protection has two stages. The first
stage turns off the field pass transistor. If the voltage still goes
higher the second stage turns on a crowbar SCR that blows an internal
5A fuse in the regulator.
From what you describe the alternator has field voltage (21.6) so it
should be generating current. With power off the field should measure
15-25 ohms. Your brushes may be worn out.
I had a problem a few years back where new brushes would not last 50
hours. I finally found that all of the replacement brush springs
were too stiff. There is two ways to fix this. Get the springs out
of a "OLD" junkyard alternator or cut a 1/4 inch off of the new
stiffer springs. I have no idea why the spring stiffness changed but
it is noticeable and measurable.
John
On Thu, 08 Jul 2004 03:53:23 GMT, "John Clonts"
I am now able to reproduce my charging problem.
Engine off, Bat and Alt on:
Bus voltage: 24.8
Supply to Voltage Regulator: 22.6
Voltage Regulator Output to Alt Field: 21.6
I'm thinking maybe I should rig a jumper from Bus to the Voltage regulator
to see if the problem has to do with that 2.2v drop through the "Alt/Reg" 5A
circuit breaker, the Alt side of the master switch, and the Overvoltage
relay.
Any comments from you electrical gurus out there?
Can anyone tell me WHERE the overvoltage relay is mounted in my Cessna 210M
(1978)?
Thanks!
John Clonts
Temple, Texas
N7NZ
Old July 8th 04, 07:54 PM
John Clonts
(John) wrote in message ...
I think mine is separate, per my comparison with the docs at
www.zeftronics.com. ("Type B" system using R25101 or R25102, not sure
which yet).
BUT I have not been able to find the OVR yet I assume its up under
the panel somewhere, but in that rats nest I can't find it. Can
anyone tell me which side? or high/low? Mounted or just hanging?
There are a few barrel-like connectors hanging around in there that
look about the same size is what I imagine the OVR to be.
The field resistance was 18 ohms. I didn't try moving the prop to see
if it varied though-- I'll try that.
Wow. We DID replace our alternator just last August at annual time,
and it has about 50-75 hours on it since then...
Thanks for your input!
Cheers,
John Clonts
Temple, Texas
N7NZ
Old July 9th 04, 02:05 AM
John_F
If your regulator case is about 3" wide by 5" tall and 1" thick and
has a round plastic plug then it has a built in over voltage relay
function. This regulator also has remote voltage sensing for both the
positive and the ground. You need to check the resistance for both of
these sense wires.
I almost died once when a Cessna with this type of regulator developed
a high resistance ground fault. If I had pulled up the electric gear
before I sucked up the electric flaps I most likely would not be here
today. The NTSB report would have said "Pilot Error". There was not
enough juice left in the battery to suck up the gear and there was
not enough power to fly level with 30 degrees of flaps on the go
around. The regulator thought the battery was charged but the battery
was slowly discharging and the under voltage light was not on nor was
the amp meter showing a discharge either.
I would look to see where the excessive voltage drop is on the
regulator power. Measure across each connection with a DVM.
You also need to check the fat ground braid between the engine case
and the motor mount frame for high resistance.
0.05 ohms will give you a 2.5 volt drop at 50 amps.
You need to get the service manual for the aircraft to check the
wiring correctly. Cessna sells the manuals for about the cost of one
gas tank fill up.
John
which yet).
Cheers,
John Clonts
Temple, Texas
N7NZ
Old July 14th 04, 05:28 AM
John Clonts
Filter/Condenser/Capacitor screw had come loose and was bouncing around
inside of alternator (Electrosystems 3eff10300aa, less than a year old!).
Unfortunately it took some diodes and the stator coil with it. Replaced
alternator. Bus voltage was somewhat high. Cleaned connectors on master
switch and plug to voltage regulator, which solved the high bus voltage AND
the "bouncing ammeter needle/flickering panel lighting" problems.
Thanks to Pete Weston at Gatesville (KGOP) for the assistance!
Cheers,
John Clonts
Temple, Texas
N7NZ
"John" wrote in message
John
Bus voltage: 24.8
regulator
5A
relay.
210M
(1978)?
Thanks!
John Clonts
Temple, Texas
N7NZ
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 03:40 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 12:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
Cessna 172 Electrical Problem Chick Urick Owning 6 September 17th 03 06:08 AM
