(John) wrote in message ...
Most of the 24 volt Cessna's have the over voltage relay built into the regulator. The over voltage protection has two stages. The first stage turns off the field pass transistor. If the voltage still goes higher the second stage turns on a crowbar SCR that blows an internal 5A fuse in the regulator. I think mine is separate, per my comparison with the docs at www.zeftronics.com. ("Type B" system using R25101 or R25102, not sure which yet). BUT I have not been able to find the OVR yet ![]() the panel somewhere, but in that rats nest I can't find it. Can anyone tell me which side? or high/low? Mounted or just hanging? There are a few barrel-like connectors hanging around in there that look about the same size is what I imagine the OVR to be. From what you describe the alternator has field voltage (21.6) so it should be generating current. With power off the field should measure 15-25 ohms. Your brushes may be worn out. The field resistance was 18 ohms. I didn't try moving the prop to see if it varied though-- I'll try that. I had a problem a few years back where new brushes would not last 50 hours. I finally found that all of the replacement brush springs were too stiff. There is two ways to fix this. Get the springs out of a "OLD" junkyard alternator or cut a 1/4 inch off of the new stiffer springs. I have no idea why the spring stiffness changed but it is noticeable and measurable. Wow. We DID replace our alternator just last August at annual time, and it has about 50-75 hours on it since then... Thanks for your input! Cheers, John Clonts Temple, Texas N7NZ |
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Cessna 172 Electrical Problem | Chick Urick | Owning | 6 | September 17th 03 06:08 AM |
