Help; Rough running Continental O-300D
Old July 9th 04, 01:31 AM
BTW -
Check that your cylinder baffling system is complete, tight to the
cylinders and properly secured to the engine, and that air loads don't
cause it to deflect away from the fins. You seem to have had a lot of
cylinder agony.
Do you have a balance problem? Above 1700 RPM the engine mounts may be
able to isolate a still-running-rough engine from the cockpit.
Be sure the plug gaps are small enough that you don't cause a marginal
ignition harness to flashover at higher power.
Does carb heat smooth things out? If so the engine is running lean.
It could also be an intake manifold gasket that has sucked in, except
that I wouldn't expect the idle to be smooth.
NRPetersen
YAMAHA FZ 750 FZ750 RUNNING GENESIS ENGINE FOR SALE Karsten Home Built 0 September 3rd 04 07:34 PM
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 04:56 PM
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) Kyler Laird General Aviation 0 March 1st 04 12:11 AM
Rough Engine, please help John Clonts Owning 14 February 26th 04 12:09 AM
rough engine just after power reduction Sydney Hoeltzli Owning 11 July 30th 03 03:37 PM
