![]() "JFLEISC" wrote in message ... The typical "output" of these pumps is a lot of air with a fair amount of oil entrained, almost like the spray from an aerosol can. I've tried 4 or 5 different units, and only the Airwolf did what it was advertised to do. I was afraid of that. Cheaper to go with a dry pump, I think. Then you have no experience with a wet pump. Dry pumps are an absolute joke. Owners rave about getting 500 hours out of one. I have a Garwin wet pump on my 182. I give it exactly zero thought. No oil on the belly from the pump either. |
That's right, I don't. What I'm interested in right now is cutting down the oil usage. It's not likely this plane will be used for IFR except possibly as a trainer. Jim |
![]() JFLEISC wrote: That's right, I don't. What I'm interested in right now is cutting down the oil usage. It's not likely this plane will be used for IFR except possibly as a trainer. In that case, make sure you keep the old vacuum pump when you replace the pump with a dry unit. You ought to be able to get a fair price for it. George Patterson In Idaho, tossing a rattlesnake into a crowded room is felony assault. In Tennessee, it's evangelism. |
![]() "JFLEISC" wrote in message ... Then you have no experience with a wet pump. That's right, I don't. What I'm interested in right now is cutting down the oil usage. It's not likely this plane will be used for IFR except possibly as a trainer. Any wet pump that uses enough oil to be noticeable is in need of overhaul. |
This is what I was wondering. I don't mind getting an overhauled pump if that will stop it's oil usage, but the feedback on this thread leads me to believe that many in this group think that 'noticable' quantities of oil out the wet vac vent tube is normal. Do I have the wrong impression here (I hope)? Jim |
JFLEISC wrote:
Any wet pump that uses enough oil to be noticeable is in need of overhaul. This is what I was wondering. I don't mind getting an overhauled pump if that will stop it's oil usage, but the feedback on this thread leads me to believe that many in this group think that 'noticable' quantities of oil out the wet vac vent tube is normal. Do I have the wrong impression here (I hope)? Jim Yes, you have the wrong impression. After owning a Skylane for several years, we had no issue with oil consumption due to the vacuum pump, but did get enough oil on the belly to require an annual clean-up. However, it takes very little oil to completely soil the bottom of an airplane. Probably less than half a cup. Matt |
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Windmilling Prop & Vacuum Pump | Matt Young | Instrument Flight Rules | 14 | October 14th 04 08:08 PM |
Wet Vacuum Pump | smackey | Owning | 6 | February 24th 04 07:03 PM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
