![]() "Michael" wrote in message om... "Richard Kaplan" wrote I think the longest I've ever had to adjust was close to two hours (I won't launch into conditions I think nothing of flying through because options are so limited on takeoff) but adjustmentst of up to 30 minutes are common. OK so suppose you are traveling due West on a 160 nm trip from Pittsburgh PA to Columbus OH and in between there is an occluded cold front with a 250 mile vertical line of thunderstorms associated with the front. The line of storms includes level 3 through 5 cells and the largest break in precip would be a circuitous path at times only 15 miles wide. I presume you are saying you would penetrate this line based on the areas where spherics show the least activity. Yet not all storm areas with hail or severe turbulence will show up on spherics, not to mention that the holes between the storms could easily close. I am not sure how I could comfortably do this trip even with multiple sources of information, i.e. spherics plus radar plus datalink, plus the ability to fly in the lower flight levels up to FL230. -------------------- Richard Kaplan, CFII www.flyimc.com |
OK so suppose you are traveling due West on a 160 nm trip from Pittsburgh PA to Columbus OH and in between there is an occluded cold front with a 250 mile vertical line of thunderstorms associated with the front. The line of storms includes level 3 through 5 cells and the largest break in precip would be a circuitous path at times only 15 miles wide. Well, that would be the day I would need up to a 125 nm deviation, now wouldn't it? How often does this actually happen? And no, spherics alone would not cut it for that kind of penetration. In fact, in my entire flying career, I've only encountered similar situations three times. Twice I followed another (RADAR equipped) aircraft while also getting RADAR assistance from approach control. In both cases, I had been maintaining a steady watch on what the weather was doing and was confident that it wasn't going to get much worse in the few minutes the penetration would require. The other time this wasn't an option. Remember the one time I needed a deviation in excess of 100 nm? Well, that was it. To be honest, I don't even think of it as a deviation if it only adds 30 minutes to my trip. After all, car trips and airline flights are routinely delayed that much. Usually, my trips are significantly longer than 160 nm (if that was typical for me, my airplane would be overkill) and so the deviations are less significant. Also, having my course line directly perpendicular to the front, while not particularly rare, is still a minority of cases. Michael |
![]() "Michael" wrote in message om... Well, that would be the day I would need up to a 125 nm deviation, now wouldn't it? How often does this actually happen? I would say this happens about weekly in the spring or summer, sometimes twice weekly. It is not rare at all. Your comments about rarely flying 160nm trips are quite relevant and may explain a difference in our perceptions -- in the Northeast it is not at all uncommon for a 160nm trip to be 1 hour flying in a 160 knot airplane or 5 hours driving in a car due to traffic issues... granted that is not the case for the trip from Pittsburgh to Columbus but in the NYC-Boston-DC corridor this is quite possible. While such short trips can be extremely convenient uses of an airplane when weather cooperates, you are correct that there are lots fewer practical deviation options on such a short trip. This may well be a big difference between general aviation in the Northeast vs. in Texas. -------------------- Richard Kaplan, CFII www.flyimc.com |
While such short trips can be extremely convenient uses of an airplane when weather cooperates, you are correct that there are lots fewer practical deviation options on such a short trip. This may well be a big difference between general aviation in the Northeast vs. in Texas. I suspect you are right. There are few meaningful destinations within 160 nm of Houston - even Dallas, which is right next door by Texas standards, is significantly farther away. My only recurring trip of under 160 nm is Austin - it is also the trip that, proportionately, gets the most delay time. It's a 45 minute trip for me in good weather; in bad weather it's not particularly rare for it to take twice that due to deviations/delays. On the other hand, it's still over two hours by car, and that's if I'm willing to speed a lot. Certainly deviations/delays for weather have a proportionally bigger impact on short trips - to the point where it may not be worth it. Of course as a result, you get less experience optimizing your deviation, and that makes the deviation even bigger. Michael |
Air Force issues ‘stop movement’ for Patrick, Cape Canaveral | Otis Willie | Military Aviation | 0 | September 25th 04 09:30 PM |
Back issues of Naval Aviation News | Steve Tobey | Naval Aviation | 0 | April 23rd 04 09:50 PM |
Article: GPS Vehicle Tracking System Issues for the Buyer | Johann Blake | Military Aviation | 0 | January 16th 04 11:26 AM |
How much could I get for these back issues? | Aaron Smith | Home Built | 8 | December 15th 03 12:07 PM |
ISO back issues Combat Aircraft magazine | mark e digby | Military Aviation | 0 | August 12th 03 05:39 PM |
