landing light
Old July 14th 04, 01:23 AM
Hankal
Default landing light
According to my parts manual Cessna 173, 1973 Serial number 17260993
My landing light should be GE 4522.
Is there a quartz replacement for this lamp?
Is this lamp available from an automotive supplier?
Old July 15th 04, 02:03 AM
COUGARNFW
No and no.
They are available as the 4522 from the catalog houses such as Spruce.
They are so robust that owners typically never have to replace them during
their ownership....because they are used so little compared to those faired
into the leading edge (4509).
When you re-install, pay attention to which side the shield of the filament is
pointed. It is meant to protect the pilot from the bright light, but at least
30 percent are 180 degrees displaced and so shine the light at the pilot and
the prop.
Neal
Old July 15th 04, 03:05 PM
Do your cowl mounted landing lites have ridiculously short life?
Old July 16th 04, 12:25 AM
OSKI 3
Use the snomobile headlight for a replacement.
Old July 16th 04, 01:08 AM
Hankal
Do they have a GE 4522?
Old July 16th 04, 01:13 AM
Hankal
is
the prop.
Only one way to install. the bulb has a notch which fits with the housing
Old July 16th 04, 06:58 AM
COUGARNFW
I did not realize that the alert about mounting would not be enough for
some....the housing for the swingdown Grimes light, which is the only one I
know of that uses the 4522 is made to be used from either wing.
Consequently, when installing the bulb, one must be sure the Grimes has been
"coded" for the wing it is to be used on. The assembly comes with an alert on
the back stating; change orientation to use on the right so that the shield
is toward the pilot such that the light does not get in his eyes!!!!
Neal
Old July 16th 04, 03:16 PM
Hankal
No a problem since mine is cowl mounted.
Hank 172 driver
Landing light Hankal Aviation Marketplace 0 July 14th 04 01:23 AM
Would a 3 million Candlepower spotlight make a good landing light? Legrande Harris Home Built 6 June 15th 04 06:32 AM
C-172 landing light switch JFLEISC Owning 10 May 5th 04 11:05 PM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
