Landing light?
Old July 18th 04, 01:19 AM
Hankal
Default Landing light?
Is an owner allowed to change (replace a defective) landing bulb.
Does it require an AP sign off?
Old July 18th 04, 02:15 AM
Aaron Coolidge
Hankal wrote:
: Is an owner allowed to change (replace a defective) landing bulb.
: Does it require an AP sign off?
You mean your lightbulbs actually BURN OUT? I have the ones that last
forever... (Grin).
Aaron Coolidge (N9376J)
Old July 18th 04, 02:27 AM
Dave S
Yes, an owner can do it, provided the owner holds a pilot certificate.
No, an A&P is not required. I do not see anything that permits an
individual non-pilot owner to perform preventative maintenance.
Chapter and verse is quoted below. Part 91 says who CANT. Part 43 goes
ahead and says who CAN perform maintenance.
Dave
§ 91.403 General.
(b) No person may perform maintenance, preventive maintenance, or
alterations on an aircraft other than as prescribed in this subpart and
other applicable regulations, including part 43 of this chapter.
§ 43.3 Persons authorized to perform maintenance, preventive
maintenance, rebuilding, and alterations.
g) The holder of a pilot certificate issued under Part 61 may perform
preventive maintenance on any aircraft owned or operated by that pilot
which is not used under Part 121, 129, or 135.
§ 43.7 Persons authorized to approve aircraft, airframes, aircraft
engines, propellers, appliances, or component parts for return to
service after maintenance, preventive maintenance, rebuilding, or
alteration.
(f) A person holding at least a private pilot certificate may approve an
aircraft for return to service after performing preventive maintenance
under the provisions of §43.3(g).
Appendix A to Part 43—Major Alterations, Major Repairs, and Preventive
Maintenance
(c) Preventive maintenance. Preventive maintenance is limited to the
following work, provided it does not involve complex assembly operations:
(17) Replacing bulbs, reflectors, and lenses of position and landing
lights.
Old July 18th 04, 10:37 PM
BTIZ
"Hankal" wrote in message
1) Is an owner allowed to change (replace a defective) landing bulb.
2) Does it require an AP sign off?
In USA
1) Does the owner hold a pilot certificate? if so.. then YES
2) If answer to (1) is YES.. then (2) = NO
BT
Old July 19th 04, 12:41 AM
Hankal
forever... (Grin)
Send it to me and I will exchange it for my failed bulb. What a deal?
Old July 19th 04, 01:42 AM
C J Campbell
A pilot may change a landing light. He is supposed to log the work in the
aircraft records, but few people bother with that.
Old July 19th 04, 05:16 PM
G.R. Patterson III
Yes.
No.
George Patterson
In Idaho, tossing a rattlesnake into a crowded room is felony assault.
In Tennessee, it's evangelism.
Landing light Hankal Aviation Marketplace 0 July 14th 04 01:23 AM
Would a 3 million Candlepower spotlight make a good landing light? Legrande Harris Home Built 6 June 15th 04 06:32 AM
C-172 landing light switch JFLEISC Owning 10 May 5th 04 11:05 PM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
