Wow! Since I haven't the slightest idea why that would matter, you
need to explain to me why this should be done in this, a very unscientific and casual comparison. I did go back and check the data, the trip was 544NM. So I guess I'll restate that I was throttled waaaaaay back so as not to run ahead of the Mooney, he was firewall forward to keep up with me and on both legs I burned about 10 gallons less than he. He has the 200 hp engine and I the 250 hp engine. Extrapolating the memory, it took me about $25 less in fuel to make each trip than it did he. I probably could have used the same fuel and arrived about an hour before, so the potential owner needs to check his mission profile before making any decision. But for $45K, I would look hard at that Mooney. Al On Wed, 11 Aug 2004 09:18:38 +0200, "Kai Glaesner" wrote: Al, Well, there was up and back with almost exactly the same results. Does that count? No ;-) If instead you would have switched and operated each others plane with the same engine/mixture management you use in your own: maybe. Determining the efficency of an airplane needs time and skill if done right. Best Regards Kai |
Al,
Wow! Since I haven't the slightest idea why that would matter, you need to explain to me why this should be done in this, a very unscientific and casual comparison. I did go back and check the data, the trip was 544NM. So I guess I'll restate that I was throttled waaaaaay back so as not to run ahead of the Mooney, he was firewall forward to keep up with me and on both legs I burned about 10 gallons less than he. He has the 200 hp engine and I the 250 hp engine. Extrapolating the memory, it took me about $25 less in fuel to make each trip than it did he. I probably could have used the same fuel and arrived about an hour before, so the potential owner needs to check his mission profile before making any decision. But for $45K, I would look hard at that Mooney. Al, strange thing if it was a M20E "flat out", "firewall forward" and with a "newly o/h'd engine". It should do about 150 TAS on ~23" and 2500 RPM on altitude and on a cruise setting, burning about 10.5 GpH. Sounds odd to me that you have to go "throttled waaaaay back" to let him keep up with you in your old Bo'. Obviously he was running with a less-than-ideal setting and burning much to much fuel, say: he has not pulled the mixture (re knob) to a setting giving something inbetween of max RPM or min SFC. Mooney's are know for their efficiency and this reputation is not based on a single event. ;-) Best Regards Kai P.S.: If you really are in the topic of measuring aircraft efficiency I would recommend using the "CAFE 400" equation to compare aircraft (look under http://www.cafefoundation.org/challenge.htm for more details) Speed^1.3 x Miles Per Gallon x Payload^0.6 Use a efficient yet safe (material and you) setting during your tests, consider running LOP (cause it's about efficiency) I'm looking forward hearing from your results... ;-) |
On Wed, 11 Aug 2004 16:24:08 +0200, "Kai Glaesner"
wrote: Al, Wow! Since I haven't the slightest idea why that would matter, you need to explain to me why this should be done in this, a very unscientific and casual comparison. I did go back and check the data, the trip was 544NM. So I guess I'll restate that I was throttled waaaaaay back so as not to run ahead of the Mooney, he was firewall forward to keep up with me and on both legs I burned about 10 gallons less than he. He has the 200 hp engine and I the 250 hp engine. Extrapolating the memory, it took me about $25 less in fuel to make each trip than it did he. I probably could have used the same fuel and arrived about an hour before, so the potential owner needs to check his mission profile before making any decision. But for $45K, I would look hard at that Mooney. Al, strange thing if it was a M20E "flat out", "firewall forward" and with a "newly o/h'd engine". It should do about 150 TAS on ~23" and 2500 RPM on altitude and on a cruise setting, burning about 10.5 GpH. Sounds odd to me that you have to go "throttled waaaaay back" to let him keep up with you in your old Bo'. Obviously he was running with a less-than-ideal setting and burning much to much fuel, say: he has not pulled the mixture (re knob) to a setting giving something inbetween of max RPM or min SFC. Mooney's are know for their efficiency and this reputation is not based on a single event. ;-) Best Regards Kai P.S.: If you really are in the topic of measuring aircraft efficiency I would recommend using the "CAFE 400" equation to compare aircraft (look under http://www.cafefoundation.org/challenge.htm for more details) Speed^1.3 x Miles Per Gallon x Payload^0.6 Use a efficient yet safe (material and you) setting during your tests, consider running LOP (cause it's about efficiency) I'm looking forward hearing from your results... ;-) Well we could get scientific about it, then start citing facts such as top mounted antennas, gap seals, paint and other factors that may bring in a total 1 kph, but the comparison is real as well as consistent. If we want to speak about performance we need to keep everything in perspective and not compare a Mooney to a Bonanza of the same vintage. I worship in the House of GAMI. My JPI hymnal is always turned to page LOP. |
Mooney drops into my backyard | Dave Butler | Owning | 41 | May 11th 04 10:19 PM |
Advice request -- buying an airplane | Casey Wilson | Owning | 4 | April 19th 04 03:22 PM |
Mooney info | eddie | Owning | 13 | March 12th 04 06:42 PM |
Mooney to Offer Light Sport Airplane | Rick Pellicciotti | Home Built | 4 | September 24th 03 01:08 PM |
Cirrus vs Mooney | Charles Talleyrand | Owning | 6 | July 8th 03 11:35 PM |
