The oil level is about 1" higher and the case is highly conductive.
Mike MU-2 "Matt Whiting" wrote in message ... Mike Rapoport wrote: The case has no more area and no more airflow across its surface with more oil in the sump. No kidding, but it does have more oil contact area and thus the oil can transfer more heat to the case. Matt |
The oil level is about 1" higher and the case is highly conductive. So, 1" times the circumference of the case is a fair bit of area and with a highly thermally conductive Al case, that will reject additional heat to be sure. Matt |
You are not getting it. How much hotter do you think the case is 1" above
the oil level? About the same. The important part of this is that you are adding more heat by raising the oil level because the crank is thrashing about in the oil. That is why the oil is vented overboard when you fill the case. Try different oil levels in your airplane and see for yourself. You probably won't be able to measure the difference unless you have a digital oil temp guage. It also take power to thrash that crank through the oil, power that would go into turning your prop otherwise. This whole issue is one reason why race cars use dry sump lubrication systems. Mike MU-2 "Matt Whiting" wrote in message ... Mike Rapoport wrote: The oil level is about 1" higher and the case is highly conductive. So, 1" times the circumference of the case is a fair bit of area and with a highly thermally conductive Al case, that will reject additional heat to be sure. Matt |
You are not getting it. How much hotter do you think the case is 1" above the oil level? About the same. The important part of this is that you are adding more heat by raising the oil level because the crank is thrashing about in the oil. That is why the oil is vented overboard when you fill the case. Try different oil levels in your airplane and see for yourself. You probably won't be able to measure the difference unless you have a digital oil temp guage. It also take power to thrash that crank through the oil, power that would go into turning your prop otherwise. This whole issue is one reason why race cars use dry sump lubrication systems. No, you're not getting it. If the oil is hotter than the case, then it will lose heat through the case. If it is losing heat through the case, then being in contact with more case area will result in more heat transfer. I honestly don't know if the oil contacts the crank in a typical Lyc or Conti. It may, it may not. I'd be very surprised if it does, because most engines with pressure lubrication systems tend to fail very quickly when any substantial amount of oil in the sump contacts the crank. That is why overfilling a crank is so strongly warned against by almost all engine makers. Matt |
Don't take my word for it! Try flying your airplane full and then at
whatever the oil level stabilizes at. If the oil didn't contact the crank, then it wouldn't be expelled out the breather (on a healthy engine). The oil may not contact the crank in level, smooth, unaccelerated flight but it does under acceleration, climb and descent. Mike MU-2 "Matt Whiting" wrote in message ... Mike Rapoport wrote: You are not getting it. How much hotter do you think the case is 1" above the oil level? About the same. The important part of this is that you are adding more heat by raising the oil level because the crank is thrashing about in the oil. That is why the oil is vented overboard when you fill the case. Try different oil levels in your airplane and see for yourself. You probably won't be able to measure the difference unless you have a digital oil temp guage. It also take power to thrash that crank through the oil, power that would go into turning your prop otherwise. This whole issue is one reason why race cars use dry sump lubrication systems. No, you're not getting it. If the oil is hotter than the case, then it will lose heat through the case. If it is losing heat through the case, then being in contact with more case area will result in more heat transfer. I honestly don't know if the oil contacts the crank in a typical Lyc or Conti. It may, it may not. I'd be very surprised if it does, because most engines with pressure lubrication systems tend to fail very quickly when any substantial amount of oil in the sump contacts the crank. That is why overfilling a crank is so strongly warned against by almost all engine makers. Matt |
Air/Oil separator Best one for $ | Ron | Home Built | 1 | September 27th 04 12:10 AM |
FA: AIRWOLF WALKER AIR/OIL SEPARATOR AFC-W315 - NEW | Mike Ferrer | Aviation Marketplace | 0 | August 29th 04 01:56 AM |
FA: Airwolf / Walker Air-Oil Separator | Mike Ferrer | Aviation Marketplace | 0 | August 23rd 04 08:15 PM |
Questions regarding Air/Oil Separators | Doodybutch | Owning | 6 | April 20th 04 05:56 PM |
