"Jim Weir" wrote:
Two years of college chemistry does not a chemist make out of me, so let's see if anybody has the answer to this one: Until we get around to making gaskets and o-rings that will stand up to alcohol, is there a cheap and easy way to chemically (or mechanically) take the alcohol out of gasoline? Yeah, I know that we could use fractional distillation, but that's a little beyond the average home kitty-litter filter process that I was contemplating. Thoughts? I guess you're thinking of something like SilcaGel (which has a high affinity for water), but in this case we need a substance that has a high affinity for ethanol but none for the hydrocarbons. Sounds like you need an Irish liver. :-) No, seriously, you might be able to use some of the laboratory-grade semi-permiable membranes, if you can find one that passes ethanol-sized molecules but not aromatic hydrocarbon-sized ones. Russell Kent |
How about using the differential solubility in water? Add water, shake to
dissolve the alochol in the water, allow to seperate, pour off the gasoline. Lather, rinse, repeat. Dave Russell Kent wrote: "Jim Weir" wrote: Two years of college chemistry does not a chemist make out of me, so let's see if anybody has the answer to this one: Until we get around to making gaskets and o-rings that will stand up to alcohol, is there a cheap and easy way to chemically (or mechanically) take the alcohol out of gasoline? Yeah, I know that we could use fractional distillation, but that's a little beyond the average home kitty-litter filter process that I was contemplating. Thoughts? I guess you're thinking of something like SilcaGel (which has a high affinity for water), but in this case we need a substance that has a high affinity for ethanol but none for the hydrocarbons. Sounds like you need an Irish liver. :-) No, seriously, you might be able to use some of the laboratory-grade semi-permiable membranes, if you can find one that passes ethanol-sized molecules but not aromatic hydrocarbon-sized ones. Russell Kent -- Dave Butler, software engineer 919-392-4367 |
