The probe goes into the Lycoming spin on oil filter adapter.
Ross john smith wrote: Ross Richardson wrote: I have a Cessna 172F with the Lycoming O-360 conversion and a C/S speed prop. My oil temperatures are always low. I pulled the probe and place in in a can of oil heated to 180 degrees and had a calibrated thermometer beside it. I marked the meter in the plane so I know where this temperature is. Even in the summer I cannot reach that temperature. I have the oil cooler mounted on the back of the rear baffle on the port side of the aircraft. It has run cool with the old engine and two years ago I installed a factory overhauled engine. Any ideas why it stays so low. Where in the engine are you measuring the temperature? |
The probe goes into the Lycoming spin on oil filter adapter. So long as the temperature of the oil returning from the engine is around 230(?) degrees F, I wouldn't be too concerned. If it isn't getting over 210, I would wonder if it was getting to all the places it is supposed to get to. |
230 is way too high on a regular basis for oil going to the cooler much
less returning to the engine from the cooler. The generally accepted number is 180 degrees at the point where most of us are getting our readings from. john smith wrote: Ross Richardson wrote: The probe goes into the Lycoming spin on oil filter adapter. So long as the temperature of the oil returning from the engine is around 230(?) degrees F, I wouldn't be too concerned. If it isn't getting over 210, I would wonder if it was getting to all the places it is supposed to get to. |
Newps wrote:
230 is way too high on a regular basis for oil going to the cooler much less returning to the engine from the cooler. The generally accepted number is 180 degrees at the point where most of us are getting our readings from. My understanding was 180 in the sump with a 50 degree F increase in the engine (hence the 230). Maybe I understand it wrong. Doesn't the engine manual give the specifics? |
Bonanza Engine Temperatures | Peter Shurman | Owning | 1 | July 11th 04 05:59 PM |
Withstanding Peak Temperatures | O. Sami Saydjari | Owning | 9 | March 2nd 04 02:32 PM |
Shock *Heating*? | Jay Honeck | Owning | 48 | February 25th 04 03:43 PM |
