"G.R. Patterson III" writes:
Hankal wrote: In the meantime can any one give some advise. My guess is a bad ground for the landing light. Huh? At worse, a bad ground will lead to little/no lamp output. I suspect a chaffed/worn wire between the breaker and the lamp. Usual technique is to put a test lamp in series, at the breaker. Then wiggle/twist/gently yank/ the wiring. When the test lamp goes to full brillance; you've found the short. The trouble here is the landing lamp will pull so much current that you'll need to use a similar lamp for the tester. Your old one would do. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
landing light | Hankal | Owning | 7 | July 16th 04 03:16 PM |
Would a 3 million Candlepower spotlight make a good landing light? | Legrande Harris | Home Built | 6 | June 15th 04 06:32 AM |
C-172 landing light switch | JFLEISC | Owning | 10 | May 5th 04 11:05 PM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
