Cost to install IFR GPS in a basic IFR 172?
Old August 25th 04, 06:01 AM
C Kingsbury
Roy Smith wrote in message ...
I wouldn't waste any time or money trying to fix an ADF today.
My point exactly. Good money after bad IMHO.
My idea is to find a good used Apollo GX-50/GX-60 unit and replace the
I don't know how much a GX-60 will add to the value of the plane. True,
it is an IFR approach certified GPS, but it's also a generation out of
date and doesn't have much sex appeal anymore.
A basic 1979 C-172 is not a vehicle for sex appeal. I want no-frills
utility. A 172 with an IFR GPS is a much more marketable beast than
one without, regardless of the GPS in question.
My club has put in a mix of CNX-80's and GX-50/60's. The CNX is a much
more expensive unit, but it's also a much better box.
Would you put a 12k GPS install into a plane with a 172 with a 40k-ish
hull value? By the time you're done we're talking about nearly the
cost of an engine overhaul, which at 1800 tach hours may not be far
off. That will add a lot more back to the value, too. You can buy an
engine for the next guy but the avionics are for the current owner.
I guess it all
depends on how deep your wallet is.
Figure somewhere between mud-puddle and pothole. Quite frankly I might
just end up repairing that damn fool ADF for just that reason.
-cwk.
Old August 25th 04, 06:50 PM
Mike H
No, no, no.... You DON'T want to try to repair that ADF.
We went that route for close to two years in our Archer, trying to
repair the Narco ADF and Navs/Coms. We just threw good money after bad.
We probably ended up sinking $2000 over a 2 year period before finally giving
in and going for a Garmin 430 and new King Nav/Com. It cost a pretty
penny (about $12000) but sure is nice now!
Mike
I guess it all
-cwk.
Old August 25th 04, 10:10 PM
PaulaJay1
In article , Mike H
writes:
I agree that you don't repair the ADF. I have the 430 installed (with a 330
transponder for TIS) in my 79Archer but a used Garmin 195 is a pretty good
inexpensive solution for VFR.
Chuck
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
