Given the age of your aircraft, I think you are best to put your money into
portables unless you need IFR. The percentage of value of even the install can get ugly. If you need more avionics, you might as well move up in plane while you are at it. "JJS" jschneider@REMOVE SOCKSpldi.net wrote in message ... I had my Cherokee in for it's vfr transponder check the other day and asked about radio upgrades. I have an Apollo/UPS/Garmin GX 65 so I asked about support for it in case something goes wrong. The avionics guy looked it up on a sheet of paper and said that Garmin is still repairing them but there was a $400 blanket charge no matter how trivial the problem. You sure want to make sure it's broke before you send it in, he said. He had a used King audio panel and was going to check into a used KX155 and glideslope for me. We're talking 4500 to $5000 to get to IFR equipped here. I'm a vfr pilot and probably won't get my IFR rating. Give me some guidance here group. Do I dump this kind of money in a 1966 Cherokee 140 in slightly better than average condition or do I invest in just a comm only to replace my fried navcom and call it good? I've read a hundred threads in the past about this subject and am still torn what to do. I'm reading in another thread about bad support on the King KX-155's, too. Joe Schneider 8437R "Ron Rosenfeld" wrote in message ... On 24 Aug 2004 12:15:08 -0700, (C Kingsbury) wrote: Googling the group yielded little so here goes... 1979 172, overall average condition with mostly original radios and wiring (one RT-385 recently replaced by a TKM radio, M1 Loran from a few centuries ago) The Cessna 300 ADF has gone flaky. The box tests fine on the bench which suggests a wild goose chase may be in store to find the gremlins. One of the two ILS approaches at my home field require ADF, and a few fields I go to are ADF/GPS-only so I need one of the two. My idea is to find a good used Apollo GX-50/GX-60 unit and replace the ADF. No need to touch the Loran, it makes a good backup. I'll get legal ADF and DME capability not to mention a moving map. Trying to convince 4 other partners this is a good idea b/c it will make it easier to sell shares in the future and even if they are VFR-only the moving map is a big plus. The local flight school says they've been spending an average of $6000 to do this with their birds at the local shop. Those of you who've done this recently, any thoughts? Bet, -cwk. Whether or not the Apollo units are a good idea or not is not something I will address. Don't forget that they are essentially "orphaned" units. Also, to be legal, there may be instances where you need to have the ADF equipment on board. However, a recent install of my CNX80 was priced at 45 man-hours for the installation (@ $60/hr = $2700). In addition to that labor cost, there was also about $1,000 in extra equipment required not included in the price of the CNX80. I believe the unit you are considering will also require remote annunciators of some sort, which would cost in addition to the labor and cost of the unit itself. $6,000 sounds about right. (My CNX80, installed, was about double that). --ron |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
