Pre-buy Inspection
Old August 31st 04, 07:32 AM
Jim Weir
I respectfully disagree. A prebuy inspection is what **I** am comfortable with.
And, as I said, I don't do them, because my comfort level is way to hell and
gone off the top end. I want that person buying that airplane to know every
little wear pattern on the airplane, in stark contrast to my annuals which
certify that no part is beyond wear or airworthiness limits.
I stick to my guns. An annual is 2 hours (more or less) of pure inspection. A
prebuy to my standards is 25 hours or so; that's my 12:1 ratio I talked about.
That's why I don't do them for anybody but myself.
(Doug)
-There really is no such thing as "a standard pre-buy". A pre buy can
-consist of anything you authorize the mechanic to do.
http://www.rst-engr.com
  #42
Old August 31st 04, 12:48 PM
Jon Kraus
Great advise... As in any business there are those that would take
advantage of others. That is not how I live my life but hey I'm the one
that has to live with "the guy in the mirror". The way that this
situation went down was that the seller didn't give an explaination as
to why he didn't want the pre-buy done at Byerly. As a side note the
sellers good friend was going to go with us to the pre-buy to overse
things.
To my partner and I it just is not worth the hassle of trying to figure
out the reason(s) for the sellers decision. I accept that. We have
decided to get our deposit back and keep on looking. There are many
planes out there and frankly it would have been an odd situation to buy
the first on we looked at. I apprecate everyones posts. Thanks !!
Jon Kraus
PP-ASEL-IA
Student airplane purchaser
C Kingsbury wrote:
Bob Noel wrote in message ...
In article , Jon Kraus
I agree with you 100%. Matter of fact the seller just informed my FBO
that he will not allow the plane to inspected by Byerly Aviation who is
a well respected Mooney shop. I think we are going to pass on this one.
something to consider: The seller might not like the shop because
of a bad experience. I know one A&P that I won't let touch my
airplane ever again (but he's not in the IL area).
Friend of mine just sold his 172. Before the buyer took it to pre-buy,
he (my friend) had his preferred mechanic do a compression check. One
cylinder was OK (mid 60s) rest in the low 70s. The prospective buyer
takes it to his guy, report comes back, one cylinder shot (58), two
questionable (61-63) and one in the high 60s. None of the results
matched up with the previous comp check. Buyer sez, "I want $2500 off
because I'm going to have to replace three jugs instead of one like
you said." My friend says, OK, how's about we take the plane together,
tomorrow, to a third shop on the same field as your guy and get it
checked there. Buyer says OK, they fly over there, and mechanic #3
does the check with the buyer over his shoulder. Everything within
1psi of the check my friend's mechanic did. Buyer got half his money
back from his (former) mechanic and bought the plane.
If it's a reputable, well-known place, I'd ask the guy for an
explanation of why he won't let you take it there. If the deal looks
good otherwise it might be worth trying to salvage.
-cwk.
  #43
Old August 31st 04, 12:52 PM
Jon Kraus
Sensitive enough to stick up for myself yes...
Morgans wrote:
"Jon Kraus" wrote in message
Probably more then you are ... you dream on Douggy.... :-)
Hmm, a bit too sensitive?
Plonk
  #44
Old August 31st 04, 12:57 PM
Jon Kraus
Ummm... wouldn't that be you Libs not me.... ;-)
PLONK, SLAM, DUNK !!!!
Plonk
  #45
Old August 31st 04, 04:14 PM
Jim Weir wrote in message . ..
That's about the furthest thing from the truth I've ever seen in these
newsgroups. A prebuy is a DOZEN times harder than an annual inspection. All an
annual inspection tells you is that nothing on the airplane is worn past service
limits at the time of the inspection.
snipped for length, not content
Heh. Having done waaay mor than fair share of pre-buy's, the best
definition of a pre-buy was the one my old boss (FBO owner, ATP-rated,
designated flight examiner, line pilot, AP/IA, new/used broker) gave
to my wife.
I was in the next hangar "inspecting" with the seller, the seller's
broker, the prospective buyer, and the prospective buyer's broker.
"Where's my husband?"
"He's next door taking it in the ass."
Pre-buy's suck, there is no formal definition under the FAR, and to do
a proper one (as you indicate) takes an incredible amount of time,
depending on the age/condition of the plane & maintenance records
being inspected.
Another "selling" broker's comment-
"I've never had anyone take two days to do a pre-buy on a single"
My response-
"Don't come back"
Have had quite a few where the aircraft, by definition, was
unairworthy (9 times out of 10 due to paperwork issues). As a
technician/inspector, my only "legal" recourse is of course to inform
the pilot/operator, and walk away.
My all-time favorites are ships recently brought back into the States.
Plus the ones that have had recent blank-check periodic inspections
from so-called "premier" make/model specific maintenance facilities
and are absolute pieces of (insert excrement of choice). Bonanza's and
Mooney's tend to fall into that category, sorry to say.
Regards;
TC
  #46
Old August 31st 04, 04:21 PM
G.R. Patterson III
Jon Kraus wrote:
As far as the pre-buy inspection goes the folks that do them
tell me that they take not anywhere near 25 hours to do.
An A&P with experience with Maules can do an annual inspection of my aircraft in
something like 18 hours. That includes all the "grunt work" that I normally do
myself. I don't find it hard to believe that someone who's really trying to do a good
job of finding every problem they reasonably can would take a few hours longer.
George Patterson
If you want to know God's opinion of money, just look at the people
he gives it to.
  #47
Old September 1st 04, 02:39 AM
Morgans
Jon Kraus
Good choice. When something does not feel right, it isn't.
I do agree with Jim W's opinion about a pre buy inspection. It should be
much more in depth than an annual. Find out what "might" have to be
replaced in the next couple/few years, vs. an annual telling you what "has"
to be replaced, right now. Also, take the time to get AD compliance well
researched, and title checked.
But you knew that, already, right? G
Jim in NC
  #48
Old September 1st 04, 02:45 AM
Morgans
I was a bit harsh. What I meant to say, was it is better off, from a
mechanic's viewpoint, to really take the time to tear into things, (not just
look on the surface) to find all the things that will cost you money down
the road, with an airplane you do not own yet.
With an airplane you already own, you will have to suck it up and keep
fixing things as they come up. It will take less time inspecting it, to do
that. IMHO
Jim in NC
  #49
Old September 1st 04, 06:03 AM
Jim Carter
Did you miss the phrase "...when the object should be to make an honest
deal"? Coins in the pocket is more important than honor to a lot of people
today, but that doesn't justify changing an agreed upon price
INDISCRIMINATELY.
I believe if you read my posts, you will see that I agreed that the
tentative, fair price should be negotiated before the pre-buy. If something
else turns up in the pre-buy that I wasn't aware of during the previous
negotiations, then I'd absolutely renegotiate based on new information. On
the other hand, if nothing turned up that I wasn't already aware of, the
honorable thing to do would be to conclude the deal based on the previously
determined fair price.
How can you disagree with this approach?
Jim Carter
  #50
Old September 1st 04, 12:42 PM
Jon Kraus
I agree that you should take the time to look into things throughly too.
I suppose that you can take this to extremes too (either way, too little
time or too much time). I certainly want to have an "expert" check out
the aircraft and associated logs carefully. My thought was that this
particular shop (Byerly) would be well prepared to do this. As far at
the time goes for how long the pre-buy would take I was just going by
what the shop said. Anyway no harm no foul. The search continues. Thanks!!
Jon Kraus
PP-ASEL-IA
that. IMHO
Home Inspection Listings Patrick Glenn Home Built 4 April 26th 04 11:52 AM
Service Manual - 50 hour inspection O. Sami Saydjari Owning 1 April 8th 04 03:17 PM
51st Fighter Wing betters rating to ‘excellent’ with inspection Otis Willie Military Aviation 0 February 20th 04 11:29 PM
100 Hour Inspection Question FryGuy General Aviation 59 November 19th 03 04:01 AM
