On Mon, 6 Sep 2004 10:37:16 -0700, "Peter Duniho"
wrote: "Ron Rosenfeld" wrote in message .. . [...] And if you are talking about a 2,000' (610m) runway with trees to the end, then yes, I would not want to be based there, given a choice. But, at least here in the US, I don't believe I've ever seen a paved, short runway where the 50' obstacle was at the beginning of the runway. I'm struggling to think of one myself. However, I have seen many paved runways with 100-150' obstacles not very far from the runway (500-1000' perhaps). These are roughly equivalent to a 50' obstacle right at the runway. Here's one of the "easier" examples of the above: http://www.airnav.com/airport/W10 Pete Well they are certainly rare. Even the example you cite really doesn't cause a big problem, if I do the math correctly. It shows a 100' tree 800' from the end of one runway. But the runway is 2400 (732 m). So to touch down with 2000' remaining requires about a 6° glide slope -- something that is certainly doable, with practice, in a Mooney. Definitely not for a new owner, or even for an old owner that hasn't flown much recently :-). I note that despite the tree, there are 28 single and 2 twin engine aircraft based at that field, and 39 operations per day! Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
... [...] It shows a 100' tree 800' from the end of one runway. But the runway is 2400 (732 m). So to touch down with 2000' remaining requires about a 6° glide slope -- something that is certainly doable, with practice, in a Mooney. "With practice". No one should land at that airport without being confident in their short field techniques, and many pilots are not. If Julian said that the Mooney simply couldn't be landed on a 2000' runway with a 50' obstacle, then I missed it. IMHO, the point is that even though it's doable, it requires even more careful attention to technique than many other airplanes would. Definitely not for a new owner, or even for an old owner that hasn't flown much recently :-). Exactly. ![]() I note that despite the tree, there are 28 single and 2 twin engine aircraft based at that field, and 39 operations per day! Well, the word "tree" in the A/FD description is misleading. What there actually is, is an entire forest of mature Douglas Fir. I'm actually a bit skeptical of the 100' height, as mature Douglas Fir is generally at least that high, and the forest north of the airport is on a hill above the airport. Anyway, even with those caveats, I'm not saying you couldn't land a Mooney there. A person flying by the numbers, using proper technique, should be fine. It's just no place to be sloppy. Pete |
... Anyway, even with those caveats, I'm not saying you couldn't land a Mooney there. A person flying by the numbers, using proper technique, should be fine. It's just no place to be sloppy. I think that's the key. I implied in my original post that the M20J requires more landing distance than comparable tourers. On reflection in the light of others' posts, and perusal of some numbers, I think that's misleading. The issue is that it's much less forgiving of any imprecision in technique. Given that we're all human, I still think that's a good reason to think hard about whether you want to base a Mooney at a relatively short field. Julian |
Any opinions on the Garmin GNS 480 ! ! ! | RonLee | Instrument Flight Rules | 18 | January 18th 05 12:33 PM |
Opinions on Cessna 340, 414 and 421 | john szpara | Owning | 55 | April 2nd 04 09:08 PM |
Opinions wanted | ArtKramr | Military Aviation | 65 | January 21st 04 04:15 AM |
OPINIONS: THE SOLUTION | ArtKramr | Military Aviation | 4 | January 7th 04 10:43 PM |
Rallye/Koliber AD's and opinions | R. Wubben | Owning | 2 | October 16th 03 05:39 AM |
