Opinions on a M20J
Old September 6th 04, 07:41 PM
Julian Scarfe
"Bob Miller" wrote in message
m...
Those numbers didn't sound right so I checked my 1965 M20C (short
rudder) manual which lists a demonstrated crosswind of 15 kt (17 mph).
I bet the M20J is higher than that.
No I promise you, it's 11 knots (at least it was on our 1982 M20J). That
doesn't necessarily mean that the M20J has less capability, just that Mooney
didn't certify it to that capability.
Julian Scarfe
  #32
Old September 6th 04, 07:50 PM
Julian Scarfe
On Mon, 06 Sep 2004 06:53:15 GMT, "Julian Scarfe"
I don't know what else you fly, Ron, but aircraft like the TB20, the
PA28s
and most light twins seem to handle crosswind take-offs with rather more
comfort.
"Ron Rosenfeld" wrote in message
Sorry about that. I did some reinstallation and my signature got changed.
But I've got over 2,500 hours in a Mooney M20E. And I presently fly out
of
a single runway airport with occasionally strong, gusty crosswinds. I've
not had a problem with crosswind takeoffs, either. Just hold the nose
down, aileron into the wind, and pop-off when ready to fly. Obviously on
a
paved strip.
Well, I was looking to see if the M20J and M20E had any differences that
would explain our difference in perception, but I'm not sure there is any.
The M20J was cleaned up by Lo Presti to the tune of about 20 knots, but
isn't it the same wing set at the same height above the ground? I've
described the issue I had in other posts, so I won't repeat it. While I
don't have your time on the aircraft, I did accumulate more than 500 hours.
And if you are talking about a 2,000' (610m) runway with trees to the end,
then yes, I would not want to be based there, given a choice. But, at
least here in the US, I don't believe I've ever seen a paved, short runway
where the 50' obstacle was at the beginning of the runway.
Grass is another story. I've been into Lubec airport (65B) which is 2024'
(617m), grass, with trees right to the end. Landing was not much of a
problem. But takeoff was close to the trees, even at 150 lbs under MGW.
I had a co-owner/partner in the Mooney group who is much braver than I was
with shorter strips. I'll check to see what he regards as "short". ;-)
Julian
  #33
Old September 6th 04, 11:10 PM
Ron Rosenfeld
On Mon, 6 Sep 2004 10:37:16 -0700, "Peter Duniho"
I'm struggling to think of one myself.
However, I have seen many paved runways with 100-150' obstacles not very far
from the runway (500-1000' perhaps). These are roughly equivalent to a 50'
obstacle right at the runway.
Here's one of the "easier" examples of the above:
http://www.airnav.com/airport/W10
Pete
Well they are certainly rare. Even the example you cite really doesn't
cause a big problem, if I do the math correctly.
It shows a 100' tree 800' from the end of one runway. But the runway is
2400 (732 m). So to touch down with 2000' remaining requires about a 6°
glide slope -- something that is certainly doable, with practice, in a
Mooney. Definitely not for a new owner, or even for an old owner that
hasn't flown much recently :-).
I note that despite the tree, there are 28 single and 2 twin engine
aircraft based at that field, and 39 operations per day!
  #34
Old September 6th 04, 11:19 PM
Ron Rosenfeld
On Mon, 06 Sep 2004 18:50:08 GMT, "Julian Scarfe"
Well, although the 'J' has the same wing, it has a longer body and a higher
MGW. But I don't know what that plus the clean up mods do for take off and
landing distances -- I don't have a POH for the 'J'. I think the stall
speed may be a few knots higher, so that could make a difference at the
margins.
  #36
Old September 7th 04, 12:26 AM
PInc972390
I can't understand that. With full
fuel in each plane, I can carry more payload than the 182.
84 gallons of fuel weigh more than 44 gallons. Seems like my 182 had a useful
load of 587 pounds with full fuel. Not much useful but could go a long way.
  #37
Old September 7th 04, 12:32 AM
PInc972390
I know a 'C' can handle a 25 kt direct crosswind.
I know a 150 with a student pilot in the dark that handled a 25 knot direct
crosswind on Dec 24, 1980 in Canadian TX.
Tried to kiss the ground but too many grassburrs.
  #38
Old September 7th 04, 03:55 AM
Bob Miller
Bob,
Let me emphasize, in case you aren't aware, that the "demonstrated"
crosswind component in our a/c is NOT a limitation. It usually reflects
ONLY the test flight done on the first day when the crosswind exceeded that
required by the regulations (which is some percentage of the stall speed -
I don't recall the exact number).
I'm aware of that.
The previous poster seemed to imply that Mooney deliberately set the
limitation low. Can any other J owners corroborate the 11 kt
demonstrated x/w for a J??
My M20C demonstrated x/w: 15 kt
My club PA32R300 demonstrated x/w: 17 kt
The M20 definitely has less rudder.
In 600 hrs I have not had the opportunity to land my C with more than
20kt of crosswind. 30 kts approaches my threshold speed of 65 kt,
which to line-up would mean crabbing to nearly 30 deg.
I'm saying that 30 kt would give me pause.
Bob Miller
  #39
Old September 7th 04, 04:25 AM
Peter Duniho
Mooney.
"With practice". No one should land at that airport without being confident
in their short field techniques, and many pilots are not.
If Julian said that the Mooney simply couldn't be landed on a 2000' runway
with a 50' obstacle, then I missed it. IMHO, the point is that even though
it's doable, it requires even more careful attention to technique than many
other airplanes would.
Exactly.
Well, the word "tree" in the A/FD description is misleading. What there
actually is, is an entire forest of mature Douglas Fir. I'm actually a bit
skeptical of the 100' height, as mature Douglas Fir is generally at least
that high, and the forest north of the airport is on a hill above the
airport.
Anyway, even with those caveats, I'm not saying you couldn't land a Mooney
there. A person flying by the numbers, using proper technique, should be
fine. It's just no place to be sloppy.
Pete
  #40
Old September 7th 04, 05:26 AM
Jack Allison
Hey Jon...keep up the posts your buying adventure. I'll be
interested to see what you finally wind up with and what the journey was
like. I'm hoping to eventually head down the ownership path. At this
point, I'm only familiar flying Cessna hardware but am definitely
interested in what you're leaning toward in the Mooney arena. Something
about 160 kts and 10 gph that just sounds like something for
nothing...er, sort of.
Nice looking plane, by the way.
Jack Allison
PP-ASEL, IA Student
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Any opinions on the Garmin GNS 480 ! ! ! RonLee Instrument Flight Rules 18 January 18th 05 12:33 PM
Opinions on Cessna 340, 414 and 421 john szpara Owning 55 April 2nd 04 09:08 PM
Opinions wanted ArtKramr Military Aviation 65 January 21st 04 04:15 AM
OPINIONS: THE SOLUTION ArtKramr Military Aviation 4 January 7th 04 10:43 PM
Rallye/Koliber AD's and opinions R. Wubben Owning 2 October 16th 03 05:39 AM
