In rec.aviation.owning Mike Rapoport wrote:
wrote in message ... snip The question remains, at what HP level, based on the physics of the engines, does the crossover from piston to turbine occur? As additional criteria, assume specific fuel consumption is the most important parameter and that the A/C spends the majority of its time in flight not doing touch and goes. I think that you can look at the market to see where the crossover occurs. THere are currently no production piston aircraft engines over 450hp and there are no aircraft turbines under 400hp. There's lots of ground turbines under 400hp so we know there's a market there; i.e. they must be practical and competive with pistons or they wouldn't sell. I thought the Chinese were still making a big radial, but I could be wrong on that one and it is a bit of a nit. If gasoline hadn't risen to twice the price of Jet-A (at least in parts of Europe), no one would be seriously discussing diesel engines for aircraft or actively developing them as several manufacturers are now. So put it this way, if it were the turbine makers instead of the diesel makers that jumped on this bandwagon, what would be their smallest engine? -- Jim Pennino Remove -spam-sux to reply. |
... If gasoline hadn't risen to twice the price of Jet-A (at least in parts of Europe) 3 times. At least for avgas. Paul |
occurs. THere are currently no production piston aircraft engines over 450hp and there are no aircraft turbines under 400hp. There's lots of ground turbines under 400hp so we know there's a market there; [...] A ground turbine runs at almost constant speed, near its design point, so even at small dimension can still be fuel efficient. Part load fuel consumption of a gas turbine is a bit too high, particularly for GA aircraft (considering their flight pprofile). -- Fritz |
"Fritz" wrote in message
... A ground turbine runs at almost constant speed, near its design point, so even at small dimension can still be fuel efficient. Part load fuel consumption of a gas turbine is a bit too high, particularly for GA aircraft (considering their flight pprofile). Hmmm...define "fuel efficient"? Your comment brings to mind the Toyota Prius hybrid engine. It essentially has a "continuously variable transmission" that doesn't involve a complicated, maintenance-hungry belt or chain and pully system. I wonder if the answer to bringing turbine engines to small airplanes might not be using a hybrid system. The weight of the batteries (which is substantial) is offset by the relatively low weight of the rest of the power train. The engine would only run during climbs, and when the batteries need to be recharged. Biggest problem I see right off the bat is the problem of starting and stopping the turbine frequently...my understanding is that there are "issues" there, but I don't know what they are, or whether they can be addressed by design. Using such a system, a turbine could be run "at almost constant speed, near its design point", while accomodating a variety of power settings. All that said, someone else mentioned turbine-engined locomotives; that's a much bigger power demand and yet somehow diesel-electric engines wound up the standard. I suppose looking at the history of train locomotives might offer some insight into how feasible hybrid technology might be for airplanes. It might be that there are some unsolveable problems, or it might be that we're at a stage in engine development now where things that used to be problems aren't anymore. Pete |
