![]() wrote in message ... In rec.aviation.owning Mike Rapoport wrote: wrote in message ... snip There's lots of ground turbines under 400hp so we know there's a market there; i.e. they must be practical and competive with pistons or they wouldn't sell. A lot of them are used to power natural gas compressors way out in the middle of nowhere and reliability is much more important than fuel efficiency and you have a large suitable fuel supply availible. True. So put it this way, if it were the turbine makers instead of the diesel makers that jumped on this bandwagon, what would be their smallest engine? Given the high initial cost of turbines and the hgiher fuel comsumption, I doubt that turbines would be competitive with gasoline engines given current price differentials between the two fuels. The beauty of a diesel aircraft engine is that it should cost the same as a gas engine, has fewer parts, uses less fuel and lasts longer. The turbine engine is more reliable but costs more and uses more fuel. The lower the hp the less competitive the turbine gets against the diesel. Your first sentence overlooks the fact that turbines are currently competitive at the Caravan level, but I pretty much agree with the rest. I don's see that I've overlooked something relative to the Caravan. The Caravan has a 940hp engine. There is currently no suitable piston engine to power such a large, single engine airplane. It couldn't be anything other than a turbine. OK, let's say I buy into about 400hp as the "up to now" crossover point. Even 400hp is not an economic crossover. It just represents the limit of what is practical in small aircraft turbine engines. The 400hp Allison turbine is really a helicopter engine anyway. The smallest practical application seems to be the around the Meridian/Caravan/TBM 700 size range and these engines are all around 1000hp. The engineers designing airplanes are not totally stupid, if it made sense to install 400hp turbines they would do so. Given the current fuel cost differential, where would you expect that point to move to assuming the engines were available? It depends on how powerful diesels get for aircraft. Under several thousand horsepower the diesel will always be cheaper and more fuel efficient than anything else. There probably isn't an economic crossover point for gasoline engines either unless the fuel price spread is artificially raised even higher than it is now. You have to remember that the HSI and overhaul costs on turbines is much greater than the cost of overhaul on a piston engine. Given that the small turbine is going to consume a lot more fuel and cost more to build and maintain it will never be cheaper. Turbines will be used in applications where cost is a secondary consideration to high power and high reliability. The gas turbine is a mature 60yr old technology, huge improvements in cost or efficiency are somewhat unlikely. For a really efficient turbine see http://www.turbokart.com/about_ge90.htm Jim Pennino Remove -spam-sux to reply. |
"Mike Rapoport" wrote in message
nk.net... I don's see that I've overlooked something relative to the Caravan. The Caravan has a 940hp engine. There is currently no suitable piston engine to power such a large, single engine airplane. It couldn't be anything other than a turbine. As you yourself pointed out, that 940hp engine is derated to 675hp. You don't need a 940hp piston engine to provide the equivalent power, and a 675hp piston engine is not out of the question (for example, the Orenda V8 turbine replacement engines are in that ballpark, if I recall correctly). Of course, the Orenda design is a good example of the general philosophy that piston engines are more efficient, and cheaper to own and operate. After all, why would anyone replace a turbine with a piston engine, if the piston engine weren't cheaper? So I'm not saying this somehow disproves your point...I'm just saying that you need to make sure you compare apples to apples (and claiming that you need a 1000hp piston engine to do the same thing a 1000hp turbine does is not comparing apples to apples). [...] The engineers designing airplanes are not totally stupid, if it made sense to install 400hp turbines they would do so. I agree the engineers are not totally stupid. I disagree that just because it hasn't made sense so far, that it will not make sense in the future. It really just depends on what factors influenced the original decision. Am I saying that I think it will make sense in the future? No...I don't know enough about the technology to be able to answer that question myself. But so far, the people who do know about the technology haven't provided any information that would suggest to me that the future will be completely void of lower-power turbines. [...] horsepower the diesel will always be cheaper and more fuel efficient than anything else. There probably isn't an economic crossover point for gasoline engines either unless the fuel price spread is artificially raised even higher than it is now. You have to remember that the HSI and overhaul costs on turbines is much greater than the cost of overhaul on a piston engine. [...] Would a HSI cost the same on a smaller turbine? Does a HSI cost the same for the PT-6 as it costs for whatever gargantuan engines the 777 uses? Inspections and overhauls for piston engines generally scale up with engine size, so it seems to me you need to compare apples to apples by comparing the cost of a HSI and/or overhaul with the cost of an inspection on a similarly powered piston engine. Turbines will be used in applications where cost is a secondary consideration to high power and high reliability. The gas turbine is a mature 60yr old technology, huge improvements in cost or efficiency are somewhat unlikely. The same thing could theoretically be said about piston engine technology. I suppose, in fact, that's one of the most compelling arguments in favor of your claim: all of the engine technologies are relatively mature, so it's reasonably safe to compare cost/benefit ratios at this time and assume that they will remain similar in the future. But can we be *sure* of that? You might think you can, but I'm not going to claim that I can. Pete |
It occurs to me that compared to a piston engine, the turbine is 1) more
expensive, and 2) more reliable. But, why are those things true? Looking at it another way, is there some inherent reason why piston engines are cheaper to produce? Is there also some inherent reason why they're less reliable? If I were to give you the $/HP budget a turbine designer has to work with, would you be able to design a piston engine that was as reliable as a turbine? |
![]() Roy Smith wrote: Looking at it another way, is there some inherent reason why piston engines are cheaper to produce? The materials are cheaper and the tolerances (especially balancing) much looser. Is there also some inherent reason why they're less reliable? The internal pressures are higher and the moving parts are constantly and rapidly reversing direction. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
"Roy Smith" wrote in message
... It occurs to me that compared to a piston engine, the turbine is 1) more expensive, and 2) more reliable. But, why are those things true? Looking at it another way, is there some inherent reason why piston engines are cheaper to produce? Is there also some inherent reason why they're less reliable? I believe that there are at least two factors: A turbine needs to be constructed out of more expensive materials, because of higher temperatures involved in the operation of the engine, and it needs to be constructed to higher tolerances, because it's very sensitive to imbalances. These contribute to cost. On the other hand, a turbine has no parts that reverse direction, while a piston engine has many such parts. So the turbine suffers less stress, when constructed correctly, than a piston engine does. It's also "simpler", in the sense that the engine doesn't need as many moving parts to accomplish the same thing. These contribute to reliability. The above ignores higher maintenance costs, which are probably related to several factors, including cost of parts, cost of training for a mechanic, and stricter maintenance guidelines (meaning maintenance happens more often and is more thorough). If I were to give you the $/HP budget a turbine designer has to work with, would you be able to design a piston engine that was as reliable as a turbine? Well, one problem is that the assertion that turbines are more reliable is, in my opinion, unproved. A well-maintained piston engine can be VERY reliable, while a poorly maintained turbine might not last very long at all. It's hard to know for sure, because most turbines are operated in an environment where there are strict maintenance standards. Those standards applied to piston engines might well result equally reliable piston engines. I think one interesting way to address your question is to look at what causes engine failures. In piston engines, it's usually some secondary component, such as fuel delivery or oil circulation. When it's a primary component, often it's something that's either suffered from poor operation techniques (valves and pistons, for example) or a manufacturing defect (crankshafts). Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). But they have stricter maintenance regimes (which more often will catch problems with secondary components), and perhaps more importantly, they have stricter operating standards and instrumentation to monitor operation (for example, overtemp operation is strictly monitored and limits specified, and if those limits are exceeded, the engine is automatically up for inspection and/or repair). Which is a long way of saying that I think it's entirely possible that if you spent as much on a piston engine as you might spend on a turbine, and followed similar practices with respect to operation and maintenance, you could achieve similar reliability rates. Pete |
![]() Peter Duniho wrote: Well, one problem is that the assertion that turbines are more reliable is, in my opinion, unproved. A well-maintained piston engine can be VERY reliable, while a poorly maintained turbine might not last very long at all. It's hard to know for sure, because most turbines are operated in an environment where there are strict maintenance standards. Those standards applied to piston engines might well result equally reliable piston engines. Perhaps a study of the durability of engines used for things like APUs, rather than aircraft powerplants would be informative. Such engines, both piston and turbine, are likely to be only moderately well maintained. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
If you really wanted to know...
You could likely compare figures derived from different models of armored fighting vehicles. Also, military aircraft used to have a mix a long time ago. "Peter Duniho" wrote in message ... "Roy Smith" wrote in message ... It occurs to me that compared to a piston engine, the turbine is 1) more expensive, and 2) more reliable. But, why are those things true? Looking at it another way, is there some inherent reason why piston engines are cheaper to produce? Is there also some inherent reason why they're less reliable? I believe that there are at least two factors: A turbine needs to be constructed out of more expensive materials, because of higher temperatures involved in the operation of the engine, and it needs to be constructed to higher tolerances, because it's very sensitive to imbalances. These contribute to cost. On the other hand, a turbine has no parts that reverse direction, while a piston engine has many such parts. So the turbine suffers less stress, when constructed correctly, than a piston engine does. It's also "simpler", in the sense that the engine doesn't need as many moving parts to accomplish the same thing. These contribute to reliability. The above ignores higher maintenance costs, which are probably related to several factors, including cost of parts, cost of training for a mechanic, and stricter maintenance guidelines (meaning maintenance happens more often and is more thorough). If I were to give you the $/HP budget a turbine designer has to work with, would you be able to design a piston engine that was as reliable as a turbine? Well, one problem is that the assertion that turbines are more reliable is, in my opinion, unproved. A well-maintained piston engine can be VERY reliable, while a poorly maintained turbine might not last very long at all. It's hard to know for sure, because most turbines are operated in an environment where there are strict maintenance standards. Those standards applied to piston engines might well result equally reliable piston engines. I think one interesting way to address your question is to look at what causes engine failures. In piston engines, it's usually some secondary component, such as fuel delivery or oil circulation. When it's a primary component, often it's something that's either suffered from poor operation techniques (valves and pistons, for example) or a manufacturing defect (crankshafts). Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). But they have stricter maintenance regimes (which more often will catch problems with secondary components), and perhaps more importantly, they have stricter operating standards and instrumentation to monitor operation (for example, overtemp operation is strictly monitored and limits specified, and if those limits are exceeded, the engine is automatically up for inspection and/or repair). Which is a long way of saying that I think it's entirely possible that if you spent as much on a piston engine as you might spend on a turbine, and followed similar practices with respect to operation and maintenance, you could achieve similar reliability rates. Pete |
... Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). Sioux City DC10. Paul |
"Paul Sengupta" wrote in message
... Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). Sioux City DC10. Not actually the accident I'm thinking of. But yes, that's another example of blade failure (did they eventually determine it was a manufacturing defect, or a maintenance problem?). The accident to which I was referring only involved one or two fatalities, of a passenger or of passengers sitting right next to the engine. Pete |
I believe you are referring to a Delta MD-80/88 that
was taking off from Pensacola. I think there were two killed and a couple of injuries. Mike Pvt/IFT N44979 PA28-181 at RYY Peter Duniho wrote: "Paul Sengupta" wrote in message ... Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). Sioux City DC10. Not actually the accident I'm thinking of. But yes, that's another example of blade failure (did they eventually determine it was a manufacturing defect, or a maintenance problem?). The accident to which I was referring only involved one or two fatalities, of a passenger or of passengers sitting right next to the engine. Pete |
