C172 fuel cap
Old September 25th 04, 05:25 AM
bill
Jim,
You're right, there is always a low pressure on the top side of the wing.
This is why a tank will drain so quickly if a fuel cap is left off or lose.
That is why the cap is vented in one direction. You want a vacuum is pull
air into the tank but don't want air pulled from the tank.
Bill
This is fantastic! And it makes so much sense. An instructor friend gave
me an
article with detailed drawings on how to position the vent. Mine was
correct
but I didn't understand (until now) why it was so critical. I would
imagine
that as the angle of attack would increase, as you say at high altitude,
there
would be a tendency for a lower pressure area to form above the right cap
as
well. What do you think?
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
C210 fuel tank vents Eric Brown Owning 2 September 27th 03 02:59 AM
