Gotta watch the temperatures around those sensors...
Up down left right is what you want to 'see'. http://zone.ni.com/devzone/devzone.n...25684A004EB0F4 "Jim Weir" wrote in message ... I've come across a marvelously cheap vibration sensor that I want to convert into an engine vibration instrument for a Kitplanes article. The electronics for me is relatively trivial...the mechanics of vibration are a little harder to fathom. From a mechanical engineering point of view on a horizontally opposed engine, there are (as with most things) three axes of freedom -- fore and aft, side to side, and up and down (longitudinal, lateral, vertical). The sensor I have reads two axes, and my hit is that fore-aft is the least interesting vibration mode of the engine. The question is whether to have a two-channel meter (which complexes up both the design AND the panel space), a single meter switchable between lateral and vertical) or a single meter with the two axes summed together. Comments and thoughts from the technonerds amongst us appreciated. (It has nothing, repeat NOTHING to do with the fact that such a meter might have detected a crack in that cylinder WAY BEFORE it departed the engine on the way home from Oshkosh {;-) ) Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Vibration Testing | Jim Weir | Home Built | 20 | October 10th 04 07:22 AM |
Testing Stick Ribs | Bob Hoover | Home Built | 3 | October 3rd 04 02:30 AM |
Survey - 3 blade prop conversion- Cockpit vibration, happy or not | Fly | Owning | 20 | June 30th 04 05:32 PM |
Stupid question about flight testing and "the envelope" | Scott Ferrin | Military Aviation | 12 | January 7th 04 03:56 AM |
Torsional Vibration Testing | B2431 | Home Built | 8 | July 25th 03 07:15 AM |
