High Oil Pressure (was: Low oil pressure, high oil temp?)
Old October 5th 04, 12:39 AM
Rip
The bearing clearances in a freshly overhauled engine are as tight as
they will ever be. And the oil pressure is as high as it will ever be.
If it's in the green, fly it.
Thomas Ploch wrote:
What about high oil pressure. My factory zero time O-235C1 is running
at around 90 psi in cruise. This is at the very top of the allowed
range.
Oil Pressure Limits - (Normal operations) Minimum 60 p.s.i. Maximum 90
p.s.i.
(Idling 25 p.s.i.)
(Starting & Warm-up) Maximum 100 p.s.i.
Is this a problem?
Low oil pressure, high oil temp? Roy Smith Owning 9 October 3rd 04 11:02 PM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
Pressure Differential in heat Exchangers Bruce A. Frank Home Built 4 July 3rd 03 05:18 AM
