PA28: Difference in constant speed prop vs fixed pitch
Old October 8th 04, 05:38 PM
G.R. Patterson III
Nathan Young wrote:
Can you better explain this? My understanding is that a fixed pitch
prop is typically a compromise in both takeoff pitch, and cruise
pitch. Using the typical car driving analogy - a prop that is stuck
in 3rd or 4th gear in a 5 speed transmission. So I would think a CS
prop would net gains at both cruise and takeoff/climb.
They usually do, for the reasons you stated. If you adjust the controls such that the
engine is producing 75% power in level flight and the CS prop settles into a coarser
pitch than the fixed pitch prop had, you'll see a faster cruise speed. If the fixed
pitch prop was pitched to produce the best cruise speed, the CS prop won't do any
better there, but will improve your ROC.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old October 8th 04, 06:38 PM
Newps
In the performance charts for my 182 a given percent power always
produces the same speed at a given altitude.
Old October 9th 04, 07:14 PM
G.R. Patterson III
I'm sure it does, but you would not see that speed if you replaced your CS prop with
a fixed pitch prop that has the compromise pitch that is commonly used on aircraft
with fixed pitch props. Most aircraft with fixed pitch props have a prop that has too
fine a pitch to get the best cruise speed at 75% power. Replacing that prop with a CS
prop will result in higher cruise speeds.
George Patterson
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
Is there a minimum prop speed? Jim Carter Owning 2 June 29th 04 01:49 AM
Constant Speed Prop vs Variable Engine Timing Jay Home Built 44 March 3rd 04 10:08 PM
Rotax 914 / Constant Speed? Richard Riley Home Built 4 February 26th 04 03:01 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
