Compression tests on both engines and swing the gear before I'd fly
it. Both of these are higher priority than a pitot static test. Also, before the compression test, several long runups, with extensive magneto and carb heat and everything else checks (temperatures etc). "Louis L. Perley III" wrote in message ... I seek the collective wisdom of the group. As I have mentioned previously, I was the co-owner of a 1965 Piper Aztec, due to various conflicts in the partnership, the plane has not flown in two and a half years (approx.) most of this time it has been in a heated hangar, but has been out in the weather since April. I have just this past week convinced my partners that it was doing no one any good to have it just sit there, and they finally let me buy them out. It's a pretty decent airframe overall, it's just been sitting idle with disuse. I know there are many things to get it airworthy again, and have started the process. I have scheduled a pitot-static-transponder check this coming week, and an annual will shortly follow. I intend to replace the tires (figure they're probably rotted due to not being moved much, and it's a easy thing to correct right at the start), install a new battery (and if memory serves I'll need to check/replace the one in the ELT as well). My question is, what else should I be checking extra carefully? I know the annual should catch most things, but that's just an inspection by definition, and I expect not everything will show up until I get it flying again. The engines have been run occasionally, but nothing that I'd call consistent. The engines do have chrome cylinders, so I'm hoping that I won't be facing a horrendous corrosion problem in that area. I'm wondering what things I should be extra careful/mindful of once the airplane is airworthy and flying again. Where would I expect to see problems the first few hours aloft? Should I keep it close to home for the first bit and then do some longer cross countries to give it a proper shakeout? If so, what would be a reasonable amount of time to shake things out? The aircraft and I are based at Jeffco (KBJC) in Broomfield, CO. I am really looking forward to taking a flight in this aircraft, as I've owned half of it for 2.5 years and have never flown it. I've seen those in the group who have been, or are in partnerships, however the whole mess surrounding this one has made such an idea in the future somewhat unpalatable. |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
