What to look for - bringing an aircraft back to life
Old October 20th 04, 01:11 AM
Louis L. Perley III
And see how old those fuel and oil hoses are. Ten years is the
outside limit, and five is more reasonable. They get brittle and crack
with age and can cause some serious second thought.
The oil filters should be checked after a couple of hours
running. Running the engines on the ground a few times puts a whole
lot of moisture into the case and causes acid formation and corrosion.
If the bearings/journals and pistons/rings have been roughed up by
corrosion there might be metal in the filters.
Dan
I plan on replacing all the hoses and such, again, as a preventative
maintanance type thing, it's a bit more cost for quite a bit of insurance in
my line of thinking, plus if I get it done now, it shouldn't be an issue for
the next few years.
On ground running the engines. I thought that as long as you ran them on the
ground long enough to get them up to operating temperature then it wasn't a
problem? Something about getting the oil hot enough to evaporate the water
or something. Is this just simply incorrect information?
Louis L. Perley III
N46000 - C152
N370 - PA-23-250
Old October 20th 04, 01:54 AM
G.R. Patterson III
Fifteen years ago, that was conventional wisdom. Now, you'll get lots of argument
about it.
As for getting the oil hot enough to evaporate water, on my Lycoming O-320, getting
into the green arc won't do the trick. You need to get the temp at least half way up
the scale and keep it there for 15 minutes or more. I can tape over my oil cooler and
manage to get it there on the ground in July or August, but the rest of the year,
ground operation won't get the engine hot enough.
Further, running the engine at all puts acids into the oil from a combination of
blowby and condensation. Unless you immediately change the oil, that acid is going to
sit in your engine. Of course, if you don't run it much (as you didn't), you won't
get much acid buildup, but it's still a problem. It's really best to just pickle the
engine if it's going to sit.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
