Off I go to help with my first annual on my C-150
Old October 22nd 04, 02:26 PM
NW_PILOT
Default Off I go to help with my first annual on my C-150
Off I go to help with my first annual tell you all how today goes later this
evening. Lets hope for the best
Old October 23rd 04, 02:16 AM
Jay Honeck
Brace for impact!
(Bring money...lots of money...)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 23rd 04, 04:38 AM
NW_PILOT
"Jay Honeck" wrote in message
news:4iied.298956$D%.72910@attbi_s51...
Brace for impact!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Inspection is done it was not that bad only a few squawks total parts outlay
so far $285.00 and $180.00 of that was in spark plugs
Compression
Cyl #1 78/80
Cyl #2 79/80
Cyl #3 78/80
Cyl #4 77/80
Tomorrow is a day of rest Sunday estimating another 5 hours to fix squawks.
1 Bad Spark Plug Totally Dead Not Firing On #3 Lower Also A 41 not a 40
2 EM-41's Replace With REM-40
Starter Bolts Not Safety Tied I Don't know how that was Missed on Pre
Purchase and last Annual?
Froze up pulley on elevator cable guide roller "barring was clogged with
dirt/lint and grit cleaned lubed functions OK!"
Front Strut & Shimmy Damper Needs Oil And Or Air Its a Little Low
Fuel Cap Seals cracking need replacing.
Gasulator drain tube broken & needs replaced
Nut Plate & Seat Rail AD complied with.
4 cowling shock mounts need replacing. 2 have cracks 2 totally broken
This was the forth set of eyes on this bird in 1 year she is getting a lot
of attention.
Old October 23rd 04, 06:07 AM
zatatime
On Fri, 22 Oct 2004 20:38:48 -0700, "NW_PILOT"
How'd you isolate this one? Were the plugs worn badly?
z
Old October 23rd 04, 04:09 PM
Jim Weir
"NW_PILOT"
-Inspection is done it was not that bad only a few squawks total parts outlay
-so far $285.00 and $180.00 of that was in spark plugs
Didn't nobody never tell you about Aircraft Spark Plug Service in Van Nuys? $75
would have gotten you a complete set of overhauled plugs for a 4-banger. The
drill is to send them your old plugs immediately after the annual and for about
$50 a set they will overhaul YOUR plugs and send them back yellow-tagged. You
then put them on the shelf for NEXT year's annual.
-Starter Bolts Not Safety Tied I Don't know how that was Missed on Pre
-Purchase and last Annual?
I'd let the IA put the words in the logbook. It appears that English is not
your primary language. See comment later about safety wire.
-Froze up pulley on elevator cable guide roller "barring was clogged with
-dirt/lint and grit cleaned lubed functions OK!"
Too many words. "Elevator cable guide roller bearing (sta 132) frozen.
Cleaned and lubricated bearing. Functional test OK.
Nobody really cares what the bearing was clogged with.
-This was the forth set of eyes on this bird in 1 year she is getting a lot
-of attention.
And three of them missed the starter safety wire? Without pulling the manual, I
can't remember whether the starter bolts have lockwashers or whether they
REQUIRE safety wire. Why do you think that safety wire is required?
http://www.rst-engr.com
Old October 23rd 04, 04:22 PM
Jim Weir
I didn't want to belabor the obvious. However, one certainly would have
suspected this, would one not?
"Jim Burns"
- 1 Bad Spark Plug Totally Dead Not Firing On #3 Lower Also A 41 not a 40
-I haven't flown a 150 in over 18 years, but didn't you notice the dead plug
-doing a mag check?
Old October 23rd 04, 04:26 PM
Jim Burns
doing a mag check?
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.775 / Virus Database: 522 - Release Date: 10/8/2004
Old October 23rd 04, 06:09 PM
Darrel Toepfer
Paid alittle more than half that ($8 ea.) for a six banger from another.
Will get the contact info if anyone is interested. Can't report on how
well they perform (ordered 12) until they arrive, should be here this
coming week...
Old October 23rd 04, 06:20 PM
zatatime
On Sat, 23 Oct 2004 12:09:04 -0500, Darrel Toepfer
Yes please.
z
Old October 23rd 04, 06:27 PM
Jim Weir
No, you paid almost exactly the same. A four-banger is eight plugs, times $8 a
plug, plus postage on ten pounds comes up to about $75.
Darrel Toepfer
-Jim Weir wrote:
- Didn't nobody never tell you about Aircraft Spark Plug Service in Van Nuys?
$75
- would have gotten you a complete set of overhauled plugs for a 4-banger.
The
- drill is to send them your old plugs immediately after the annual and for
about
- $50 a set they will overhaul YOUR plugs and send them back yellow-tagged.
You
- then put them on the shelf for NEXT year's annual.
-Paid alittle more than half that ($8 ea.) for a six banger from another.
-Will get the contact info if anyone is interested. Can't report on how
-well they perform (ordered 12) until they arrive, should be here this
-coming week...
Annual Coronary Jay Honeck Owning 19 May 24th 04 03:47 AM
1st Annual Sky Pup Litter Meet Edwin Home Built 0 May 23rd 04 05:16 PM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
Another Almost Annual Christmas Poem!!! David Pincus Home Built 4 December 28th 03 12:47 PM
Pre-Purchase Annual? Paul Millner Owning 1 July 4th 03 10:11 PM
