On Sun, 24 Oct 2004 13:40:03 GMT, "Jay Honeck"
wrote: What do you guys use on your yokes? Is there anything that lasts longer than silicone spray that (a) doesn't stain carpet, (b) doesn't stink to high heaven, and (c) doesn't leave particulate matter behind? An IA friend of mine recommended Dow Corning #4. Its labeled as an Electrical Insulating compound, but contains silicone and it a great lube. It even meets MIL Spec 8660. I had a similar problem when I bought my bird, someone used something that gummed up the works. I also was very irritated on landings when I'd apply a little back pressure (nothing happened), a little more (nothing happened), a little more and the yoke came back 2 inches. (Crap!) This stuff comes in a squeeze tube, so spray doesn't go everywhere, and provides about 9 months of lube since its thicker and remains on the yoke longer (while it was getting gunk out it didn't last as long). It also helped clean out a whole bunch of junk from the bushings. I highly recommend this to anyone. A little bit goes a long way. HTH. z |
I use a bit of TriFlow (from my bicycle kit), munge the yoke
back & forth, in & out as if flying then wipe it off. |
Elite and CH Flight Sim Yoke - USB | tscottme | Instrument Flight Rules | 3 | December 21st 10 11:34 PM |
Beech dual yoke w/rams horns/color preference | Dan Karshin | Aviation Marketplace | 1 | March 28th 04 05:04 PM |
CH Product Yoke with IP Trainer 6.5 | Sanjay Kumar | Instrument Flight Rules | 2 | October 10th 03 07:47 AM |
MS Flight Sim 2004..............which yoke is best? | TripFarmer | General Aviation | 0 | September 29th 03 09:46 PM |
Yoke grips | Jose Gibert | Aviation Marketplace | 0 | September 9th 03 03:17 AM |
