"Dude" wrote in message ...
These events are held regularly, and allow you to bring your plane and log books to the field for an audit and inspection with no risk of being fined or cited. Sort of like an amnesty program. And, it's free. Sounds great, but... The risk is not being fined or cited, the risk is that you'll never be able to fly your plane home after the audit. It's quite possible that a nitpicky inspector could ground your airplane because of ancient paperwork issues (not safety related ones, either). As far as I'm concerned, this program is like taking your last 5 years of financial data to the IRS and asking them if they can find a violation. Do you really want to open that can of worms? When they say, "I'm from the government and I'm here to help", you're not supposed to take 'em seriously :-) John Galban=====N4BQ (PA28-180) |
Well, I have never heard of anyone being held on the field at a Pace event.
If that were to happen, then we should all hear about it, and find out who got fired. OTOH, the FAA is the FAA. I suspect that your example is misleading, because that type of plane is exactly what they want to fix. If a plane was seriously dangerous due to physical imperfection, rather than log problems, I suppose someone might get strongly pressured to not fly it out. But it would have to be an obvious hazard that no reasonable pilot would want to ignore. If your example were real, the program would end up being a joke. "John Galban" wrote in message om... "Dude" wrote in message ... These events are held regularly, and allow you to bring your plane and log books to the field for an audit and inspection with no risk of being fined or cited. Sort of like an amnesty program. And, it's free. Sounds great, but... The risk is not being fined or cited, the risk is that you'll never be able to fly your plane home after the audit. It's quite possible that a nitpicky inspector could ground your airplane because of ancient paperwork issues (not safety related ones, either). As far as I'm concerned, this program is like taking your last 5 years of financial data to the IRS and asking them if they can find a violation. Do you really want to open that can of worms? When they say, "I'm from the government and I'm here to help", you're not supposed to take 'em seriously :-) John Galban=====N4BQ (PA28-180) |
![]() "Dude" wrote in message ... Well, I have never heard of anyone being held on the field at a Pace event. If that were to happen, then we should all hear about it, and find out who got fired. OTOH, the FAA is the FAA. I suspect that your example is misleading, because that type of plane is exactly what they want to fix. If a plane was seriously dangerous due to physical imperfection, rather than log problems, I suppose someone might get strongly pressured to not fly it out. But it would have to be an obvious hazard that no reasonable pilot would want to ignore. There are very few FAA people that can tell an airworthy airframe from one that is unairworthy. They can look over paperwork but beyond that don't expect much.. |
Dave Stadt wrote:
: There are very few FAA people that can tell an airworthy airframe from one : that is unairworthy. They can look over paperwork but beyond that don't : expect much.. ... and if you look hard enough at *ANY* aircraft, you will conclude that it unairworthy. One piece of non MIL-spec'd heat shrink tubing or wire end. One lightbulb gotten at AutoZone rather than a PMA'd one. That one screw on the spinner that wasn't torqued with a calibrated torque wrench. The list is long, but in true leagaleaze, anything not done according to approved data is unacceptable. I've heard horror stories about going to the FSDO for a CFI-checkride and having the FAA droids comb over your aircraft. Alegedly one guy came in with a plane that had a pin-head sized air bubble in the wet compass that couldn't be seen without putting your head down on the floor and looking up at it. *POOF* unairworthy (no air is acceptable). If you're lucky they'll let you ferry it home. Again, "We're with the FAA and we're here to help..." -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Sure, we have all heard those stories, and I have been a victim of a similar
case of the letter over any sense whatsoever type of judgement. However, NOT AT A PACE EVENT. And, that is what's important. The FAA gives you can opportunity to get their opinion with no penalty, so you can pencil whip or fix problems on your own time without being grounded. wrote in message ... Dave Stadt wrote: : There are very few FAA people that can tell an airworthy airframe from one : that is unairworthy. They can look over paperwork but beyond that don't : expect much.. ... and if you look hard enough at *ANY* aircraft, you will conclude that it unairworthy. One piece of non MIL-spec'd heat shrink tubing or wire end. One lightbulb gotten at AutoZone rather than a PMA'd one. That one screw on the spinner that wasn't torqued with a calibrated torque wrench. The list is long, but in true leagaleaze, anything not done according to approved data is unacceptable. I've heard horror stories about going to the FSDO for a CFI-checkride and having the FAA droids comb over your aircraft. Alegedly one guy came in with a plane that had a pin-head sized air bubble in the wet compass that couldn't be seen without putting your head down on the floor and looking up at it. *POOF* unairworthy (no air is acceptable). If you're lucky they'll let you ferry it home. Again, "We're with the FAA and we're here to help..." -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() Dude wrote: If a plane was seriously dangerous due to physical imperfection, rather than log problems, I suppose someone might get strongly pressured to not fly it out. Nobody at the Teterboro FSDO is capable of determining this -- that's what your local IA is supposed to do every year. PACE events are intended to uncover problems with the paperwork; nothing more. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
At our last PACE event, the FAA examiners were actually inspecting the
planes as well.. Whether it did any good or not... ??? "G.R. Patterson III" wrote in message ... Dude wrote: If a plane was seriously dangerous due to physical imperfection, rather than log problems, I suppose someone might get strongly pressured to not fly it out. Nobody at the Teterboro FSDO is capable of determining this -- that's what your local IA is supposed to do every year. PACE events are intended to uncover problems with the paperwork; nothing more. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
Well, I have never heard of anyone being held on the field at a Pace event. If that were to happen, then we should all hear about it, and find out who got fired. Fired? That's a good one! OTOH, the FAA is the FAA. I suspect that your example is misleading, because that type of plane is exactly what they want to fix. If a plane was seriously dangerous due to physical imperfection, rather than log problems, I suppose someone might get strongly pressured to not fly it out. But it would have to be an obvious hazard that no reasonable pilot would want to ignore. As far as the FAA is concerned, paperwork is what makes a plane fly. The interpretation of the regs appears to be at the whim of the inspector and varies from FSDO to FSDO (and even between inspectors in the same FSDO). Let's suppose an inspector found something, say an STC, that wasn't properly logged (in his opinion). According to the regs, your airplane would not be airworthy in paperwork sense. Are we supposed to trust that the FAA is going to look the other way as we climb into our unairworthy (on paper) airplane and fly it home to the shop? Most of the FSDO inspectors that I know would not put their butts on the line like that. More likely, you'd have to jump through the hoops required for a ferry permit. I know dozens of airplane and FBO owners and no one (so far) has ever seriously considered participating in this program. It has nothing to do with whether an airplane is actually airworthy and exposes you to the regulatory whims of your local FSDO. The best bet for a good assesment of actual airworthiness is still an experienced IA. If your example were real, the program would end up being a joke. I didn't actually give an example in my first post, just pointed out possible pitfalls. Most owners I know think that the program is a joke and wouldn't touch it with a ten foot pole. As I said in my first post, it requires you to believe that the FAA is "here to help". John Galban=====N4BQ (PA28-180) |
"Dude" wrote
Well, I have never heard of anyone being held on the field at a Pace event. If that were to happen, then we should all hear about it, and find out who got fired. I've heard about it. Nobody got fired. If your example were real, the program would end up being a joke. And so it is. Michael |
Well, tell us the details. Inquiring mids want to know.
"Michael" wrote in message om... "Dude" wrote Well, I have never heard of anyone being held on the field at a Pace event. If that were to happen, then we should all hear about it, and find out who got fired. I've heard about it. Nobody got fired. If your example were real, the program would end up being a joke. And so it is. Michael |
