The Avionics shop discovered that the comm side board is bad. It has to
go back to Garmin for the $600.00 refurb.... JK Marty from Sunny Florida wrote: If you hit the PTT and your antenna is not correctly connected to the 430, you can damage the 430. I'd have a radio guy look at it before messing around too much. On occasion, just looking can do some damage. Just a thought ... Marty from Sunny South Florida "Jon Kraus" wrote in message ... Yes I can receive (hear) on 123.05 and the "TX" shows up as I push the "press to talk" switch. Just UNICOM can not hear me from the ground. Unfortunatly the only freq on this airport is the UNICOM 123.05 and the AWOS which is 120.725. Mike Rapoport wrote: First check that the TX annunciator comes on the 430 when you transmit. It is right there with the COM frequencies in the upper left corner. If the annunciator is coming on then check the antenna. I assume that you can hear on 123.05? Mike MU-2 "Jon Kraus" wrote in message ... My partner and I just bought a '79 Mooney M20J with a 2 year old Garmin 430 Comm/Nav as the Comm # 1 adn a Bendix 170B as the Comm/Nav # 2. (yes we had a pre-buy and everything "seemed" fine") I have some strange issues with the 430 that I am sure you can help guide me thru. Issues: 1.) On the ground if you set the 430 to our UNICOM freq TYQ 123.05 and do a radio check they can not hear you. TYQ has an AWOS and you can hear that fine on the ground (120.725). 2.) On the ground if you set the 170B (nav/com # 2) and do a radio check they come back as "loud and clear" (and yes they are at the station when I try the radio check on comm 1) :-) 3.) One time we were on the ground set up on the Comm 1 and trying to get the UNICOM operator to hear us when a Piper over the airport said we were "loud and clear". 4.) Our local UNICOM is 123.05. UMP an airport 15 miles away's UNICOM is 123.00. While airborn we kept picking up their transmissions. I was going to try swapping antenna connections between Comm 1 and Comm 2 but as I peered under the dash looking for the antenna leads I said "I'll screw more up then I'll ever fix so I left it alone) Any suggestions or advise? Is this going to cost a fortune to fix? Thanks in advance for your help!! Jon Kraus PP-ASEL-IA Student Mooney Owner 4443H @ TYQ |
| Thread Tools | |
| Display Modes | |
| Garmin 430 Reception | Jon Kraus | Owning | 16 | November 7th 04 04:17 AM |
| Garmin 296 worth the money? | Terry | Owning | 15 | June 22nd 04 10:03 AM |
| How much could I get for these back issues? | Aaron Smith | Home Built | 8 | December 15th 03 01:07 PM |
| Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 03:04 AM |
| Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 10:04 PM |
