Mike Noel wrote:
I want to protect my vacuum instruments with a filter between the vacuum regluator and the (dry) vacuum pump on my 74 Archer. Spruce sells the Clearview for about 50 bucks, and sells the filter plus mounting hardware and STC for about 85 bucks. Does anyone have any experience with this or other inline filters? I'm guessing the the extra 35$ is for the STC and a couple of clamps. I installed a clearview filter last year after troubleshooting a vacuum system gremlin. My experience, in short, is that installing an inline filter of any kind between the vacuum pump and the regulator is just good common sense. Call it cheap insurance. The clearview filter indeed works as advertised...it can be easily inspected and replaced on condition. As you surmised, you need to buy the $85 kit first and get the STC signed off by an IA, and then you can replace the filters with a logbook entry. I wrote an article about the installation process that applies to this part and parts like it. Click through: Aviation - Articles - Maintenance - FAA/PMA Parts, STCs, and 337's. Hope this helps. -Doug -- -------------------- Doug Vetter, CFIMEIA http://www.dvcfi.com -------------------- |
K&N Performance Gold Oil Filter? | MikeremlaP | Home Built | 0 | September 3rd 04 05:58 PM |
K&N Air Filter | tony roberts | Owning | 3 | May 31st 04 05:26 AM |
Filter element for Frantz filter | Philippe | Owning | 1 | April 20th 04 08:23 PM |
where exactly to put the noise filter | Dico Reyers | Owning | 25 | February 25th 04 03:21 AM |
Airwolf oil filter system | kevin | Owning | 3 | August 7th 03 04:24 PM |
